| 产品名称: |
工控机
| 型 号: |
Ultra400 |
| 价 格: |
0.00 |
| 品 牌: |
BESDE |
产品介绍: |
The Ultra400 Series workstation is a high performance design in a low cost 4U rack mount enclosure. Feature rich, the Ultra400 Series workstation is a solid, robust design which will meet the most rigorous and demanding requirements. This workstation is ideal for I/O intensive applications such as telephony, data acquisition, Digital Video Recording (DVR), high density web server, back office server, firewall, proxy server and VPN gateway applications including collocation The enclosure is constructed of 18 gauge steel, clear zinc plated for corrosion protection and an attractive appearance. The front panel is attractively detailed and is of heavier gauge than the chassis The chassis provides for three 5.25-inch drives and one 3.5-inch drive, all front accessible. Various drive adapters are available to allow hot-swap IDE and SCSI drive configurations The power supply is a redundant supply A full width lockable door covers and protects the drives. Accessible behind the door is the power and reset switches. The HDD LED's are mounted on the door A full width filter is provided behind the door and is easily accessed for cleaning. Cooling is provided by one 120CFM fans The Ultra400 Chassis provides for mounting an ATX motherboard or accepts a 14-slot passive backplane. An innovative card hold-down mechanism assures cards stay seated in high-G environments such as shipping Dimensions 19" (wide) x 4U (6.95") (high) x19.7” (deep) Drive Capacity Three horizontal 5-1/4 inch half height drives - front accessible One horizontal 3-1/2 inch x 1 inch drive - front accessible The drive cages are suspended on anti-vibration mounts Front Panel Controls Power switch - large black momentary with 1 position .100 header for board connection Reset switch - small black momentary with 1 position .100 header for board connection* Power - RED LED with 1 position .100 header for board connection HDD. - green LED Cooling One 120CFM fans Power Supply AC Input 115/230v – 300W max DC output Zippy RAH and RHH form factor Optional 12, 24 or 48VDC supplies available Alarm Board (optional) Fan operation Chassis temperature Redundant power supply failure Certification CE(EN55022 class B)/FCC(class B) MTBF: >100000 H Ambient Temperature Operating temperature test:0~50℃ Non- Operating temperature test:-40~70℃ Non-condensing humidity:10%~95% |
