点击看大图
产品名称: 工控机
型  号: Ultra200
品  牌: BESDE
产品介绍: Ultra200S Series
The Ultra200 Series is a high performance design in a low cost 2U rack mount enclosure. Feature rich, the Ultra200 Series is a solid, robust design which will meet the most rigorous and demanding requirements. This chassis is ideal for high density I/O intensive applications
The enclosure is constructed of 18 gauge steel, clear zinc plated for corrosion protection and an attractive appearance. The front panel is attractively detailed and is of heavier gauge than the chassis
The Ultra200 provides for one externally accessible 5-1/4 inch and one 3-1/2 inch drive bays. In addition, six hot swap IDE drives provide for a large amount of low cost IDE drive space. The IDE drives can easily be configured for a large RAID. The Ultra200 is ideal for cost sensitive data intensive or mission critical applications
The chassis is cooled by four 80mm 42CFM ball bearing fans. Air flow is in through a front mounted air filter. The fans are mounted mid-chassis to help cool the drives. A thermal management card monitors fan operation and chassis temperature providing both an audible alarm and contact closure output
A door covers and protects the drives. Accessible behind the door is the power and reset switches as well as the power-on and drive activity LED's. The LED's are visible through the door when it is closed
The Ultra200 Chassis provides for mounting a standard EATX motherboard up to 12 x 13-inches. Two plug-in cards can be installed using the included riser card. Additionally, several riser card options are available.
Specification
Feature Description
Dimensions 19" (wide) x 2U (3.5") (high) x 25.6" (deep) Weight - 28.6 lbs / 13 kg
Drive Capacity One 5-1/4 inch drive - front accessible One 3-1/2 inch drive - front accessible Six hotswap IDE drives
Front Panel Controls Power switch Reset switch Alarm reset switch Power LED Drive Activity LED
Cooling Four 80mm 42CFM fans Fans are mounted mid-chassis to assist with drive cooling
Power Supply AC Input 115/230v – 450W max DC output Zippy RAH and RHH form factor Optional 12, 24 or 48VDC supplies available
Alarm Board (optional) Fan operation Chassis temperature Redundant power supply failure
Certification CE(EN55022 class B)/FCC(class B)$4 MTBF
Ambient Temperature Operating temperature test:0~50℃ Non- Operating temperature test:-40~70℃ Non-condensing humidity:10%~95%
公司名称: BESDE technology (shanghai) co.,ltd.
电  话: 021-68316055 / edjiang
传  真: 021-68316057
地  址: (上海市)上海洪山路501弄30号
邮  编: 200126
主  页: http://WWW.BESDE.COM
  • cpu card(PAI-811 Series)
  • cpci(cSP-7001 Series)
  • cpci(cPCIS-3300)
  • cpci(cPCIS-3330)
  • 工控机(ultra600)
  • 工控机(fw-1500)
  • 工控机(fw-1800)
  • 工控机(fw-2000)
  • 工控机(Ultra100)
  • 工控机(Ultra400)
  • 更多产品...
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
