产品介绍: |
FW-2000 For any Server Room, Data Center, Enterprise Level use. 6 x 10/100 Mbps Fast Ethernet ports. 6 x Intel® 82551 NIC\'s. 2 x RS-232 serial ports. Supports Compact Flash card. Supports Flash-based DiskOnModule. Supports Socket 478 processors. Supports up to 2GB DDR266 SDRAM. Optional IPSec Encryption Accelerator Specification Feature Description Standard IEEE 802.3 10Base-T IEEEE 802.3u 100Base-TX Network Media Ethernet: UTP Cat. 3, 4, 5 Fast Ethernet: UTP Cat. 5 Protocol CSMA/CD LAN Six (6) Intel®82551ER Fast Ethernet Controllers Three (3) Kbyte transmit and receive FIFO's Full-duplex support at both 10 and 100 Mbps operation Network Data Transfer Rate Ethernet: 60 Mbps (Half-duplex) 120 Mbps (Full-duplex) Fast Ethernet: 600 Mbps (Half-duplex) 1200 Mbps (Full-duplex) Storage Media Compact Flash socket for Compact Flash card One ATA66/100 IDE connector for DiskOnModule®or IDE device IPSec Encryption Accelerator (Optional/Choice Of) Broadcom®BCM 5823-200 Security Processor High-Performance Security Co-Processor (256PBGA) 200 Mbps system throughput DES-CBC, 3DES-CDC AES-CBC, AES-CTR (up to 256-bit key lengths) HMAC-SHA-1, HMAC-MD5 Single pass encryption and authentication Integrated Public Key Processor Diffie-Helman Key Generation and Agreement up to 2048-bits RSA Public and Private Key operations up to 2048-bits Support for IKE and SSL/TSL modes Cavium Nitrox Lite Security Macro Processor (256PBGA) CN1001 supports 100 Mbps 3DES+SHA1 w/ 1000DH (180-bit) Support for RSA, Diffe-Hellman, DES/3DES, AES, ARC4 MD5, SHA-1, HMAC-MD5/-SHA-1, True Number Generator I/O Interface 6 x 10/100 Mbps auto-negotiation Ethernet ports 2 x External serial ports Internal Slots and Connectors 1 x PCI2.2 compliant RISER slot 2 x PS/2 pin-headers for keyboard and mouse 1 x Parallel port pin-header 1 x Internal USB2.0/1.1 connector 1 x GPIO port pin-header 1 x VGA pin-header Processor Supports single Socket 478 Intel®Pentium®4 processor Supports 533/400 MHz FSB Supports Intel®Pentium®4 processor speeds ranging from 1.5 to 2.53 GHz or above Supports Intel®Pentium®4 Celeron™processor speeds ranging from 1.7 to 1.9 GHz or above System Memory 2 x 184-pin DDR DIMM slots Supports up to 4GB DDR memory Supports PC2700/2100/1600 (DDR333/266/200) SDRAM Supports Unregistered, non-ECC DDR SDRAM only Chipset Intel® 845GV chipset • 82845GV Graphics and Memory Controller Hub (GMCH) • 82801DB I/O Controller Hub 4 (ICH4) Power Input voltage: 90-264/190-264 VAC, Full range Frequency: 47 - 63 Hz Dimensions 1U Rack Mountable 19 in [W] x 1.75 in [H] x 9 in [D] (482.5mm x 44.5mm x 227mm) 8 lbs (3.63 kg) Temperature Operating: 0° - 40° C Storage: -10° - 70° C Humidity Operating: 10% - 90% RH |
