产品介绍: |
FW-1800 For Any Server room, Data center, Enterprise Level use 4 x 10/100Mbps Fast Ethernet port 4 Intel® 82559ER NICs 2 RS-232 Serial Ports Supports Compact Flash Card Supports DiskOnModule™ like flash memory Supports Socket 370 Processors Supports up to 512MB PC133 SDRAM Specification Feature Description Standard IEEE 802.3 10Base-T IEEEE 802.3u 100Base-TX Network Media Ethernet: UTP Cat. 3, 4, 5 Fast Ethernet: UTP Cat. 5 Protocol CSMA/CD LAN Number of Ports4 10/100Mbps Auto-negotiation Ethernet ports 4 Intel® 82559ER Network interface Controllers 128 Kbyte Flash interface Full duplex support at both 10 and 100 Mbps operation Network Data Transfer Rate Ethernet: 40 Mbps (Half-duplex) 80 Mbps (Full-duplex) Fast Ethernet: 400 Mbps (Half-duplex) 800 Mbps (Full-duplex) Storage Media Compact Flash socket for Compact Flash card One ATA66/100 IDE connector for DiskOnModule® or IDE device IPSec Encryption Accelerator (Optional/Choice Of) Broadcom® BCM 5823-200 Security Processor High-Performance Security Co-Processor (256PBGA) 200 Mbps system throughput DES-CBC, 3DES-CDC AES-CBC, AES-CTR (up to 256-bit key lengths) HMAC-SHA-1, HMAC-MD5 Single pass encryption and authentication Integrated Public Key Processor Diffie-Helman Key Generation and Agreement up to 2048-bits RSA Public and Private Key operations up to 2048-bits Support for IKE and SSL/TSL modes Cavium Nitrox Lite Security Macro Processor (256PBGA) CN1001 supports 100 Mbps 3DES+SHA1 w/ 1000DH (180-bit) Support for RSA, Diffe-Hellman, DES/3DES, AES, ARC4 MD5, SHA-1, HMAC-MD5/-SHA-1, True Number Generator I/O Interface 4 x 10/100 Mbps auto-negotiation Ethernet ports 2 x External serial ports Internal Slots and Connectors 1 x PCI2.2 compliant RISER slot 2 x PS/2 pin-headers for keyboard and mouse 1 x Parallel port pin-header 1 x Internal USB2.0/1.1 connector 1 x GPIO port pin-header 1 x VGA pin-header Processor Supports single Socket 370 Supports 66/100/133MHz FSB Supports Intel® Socket370 Pentium® III / Celeron® Coppermine and Tualation Supports VIA C3™ System Memory 2 x 168-pin DDR DIMM slots Supports up to 512M SD memory Supports PC100/133 SDRAM Supports Unregistered, non-ECC DDR SDRAM only Chipset Intel® 815EP chipsets MCH (Intel® 82815EP) Memory Control Hub ICH2 (Intel® 82801BA) I/O Control Hub Power Input voltage: 90-264/190-264 VAC, Full range Frequency: 47 - 63 Hz Dimensions 1U Rack Mountable W x H x D - 19" x 1.75" x 10.6" (482.5mm x 44.5mm x 270mm) Temperature Operating: 0° - 40° C Storage: -10° - 70° C Humidity Operating: 10% - 90% RH |
