点击看大图
产品名称: 工控机
型  号: ultra600
品  牌: besde
产品介绍: Ultra600w Series
The Ultra600 Series workstation is a high performance design in a low cost 6U rack mount enclosure. Feature rich, the Ultra600 Series workstation is a solid, robust design which will meet the most rigorous and demanding requirements. This workstation is ideal for I/O intensive applications such as telephony, data acquisition, Digital Video Recording (DVR), high density web server, back office server, firewall, proxy server and VPN gateway applications including collocation
There is a huge amount of drive space with the seven front accessible 5-1/4" drive bays. This allows for a low cost RAID implementation using SCSI or ATA drives. One external 3.5 inch drive is also available
A door covers and protects the drives. Accessible behind the door is the power and reset switches as well as the power-on and drive activity LED's. The LED's are visible through the door when it is closed
Cooling is provided by four 90mm 51CFM( hot swap option) fans. The thermal management board monitors fan operation
The Ultra600(EATX) series provides for mounting a standard Extended ATX (EATX) motherboard up to 12 x 13-inches. Depending on the CPU selection, up to 7 plug-in cards can be installed. This chassis is perfect for mounting a server class dual processor motherboard
The Ultra600 series provides for mounting a 20-slot passive backplane. A wide variety of backplanes are available offering different mixes of ISA and PCI slots. Depending on the CPU selection, up to 19 plug-in cards can be installed. The workstation chassis is designed to accomodate split backplanes offering support for up to 4 splits
Power is provided by rear mounted PS/2 style power supply. Several power supply options are available including redundant power
Specification
Feature Description
Dimensions 19" (wide) x 6U (10.45") (high) x 19.7" (deep)
Drive Capacity Seven 5-1/4 inch drives - front accessible One 3-1/2 inch drive - front accessible
Front Panel Controls Power switch - Black momentary rocker with 2 position .100 header for board connection Reset switch - Four pushbuttons with 2 position .100 header for board connection* Power LED - Green with 3 position .100 header for board connection Drive Activity - Red with 2 position .100 header for board connection Switch and LED connectors are labeled at the connector end. * Note: Four reset switches are provided for use with up to a 4 section segmented backplane
Cooling Four 90mm 51CFM fans Positive chassis pressure Full-width air filter located behind drive door.
Power Supply AC Input 115/230v – 500W max DC output (Zippy RAH and RHH form factor option) Optional 12, 24 or 48VDC supplies available
Alarm Board (optional) Fan operation Chassis temperature Redundant power supply failure
Certification CE(EN55022 class B)/FCC(class B) MTBF:>100000 H
Ambient Temperature Operating temperature test:0~50℃ Non- Operating temperature test:-40~70℃ Non-condensing humidity:10%~95%
公司名称: BESDE technology (shanghai) co.,ltd.
电  话: 021-68316055 / edjiang
传  真: 021-68316057
地  址: (上海市)上海洪山路501弄30号
邮  编: 200126
主  页: http://WWW.BESDE.COM
  • cpu card(PAI-811 Series)
  • cpci(cSP-7001 Series)
  • cpci(cPCIS-3300)
  • cpci(cPCIS-3330)
  • 工控机(fw-1500)
  • 工控机(fw-1800)
  • 工控机(fw-2000)
  • 工控机(Ultra100)
  • 工控机(Ultra200)
  • 工控机(Ultra400)
  • 更多产品...
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
