产品名称: cpu card
型  号: PAI-811 Series
品  牌: besde
产品介绍: BESDE PAI-811 SBC (Single Board Computer) is an all-in-one industrial full-size PICMG (PCI/ISA)-bus CPU card based on Intel mPGA478 Pentium 4 architecture. With Intel 82865G series chipset, FS-978 offers the value solution with Intel NetBurst micro-architecture, 400/533/800 MHz of FSB, 2 GB DDR SDRAM, Supports bandwidth up to 3.2GB/s(DDR400) for Single Channel mode and 6.4GB/s (DDR400) in Dual Channel mode. Supports non ECC DIMMs, Intel 82865G GMCH built-in 256bit 3D VGA controller, share memory up to 64MB, Supports one external D-sub 15-pin connector & one internal 15-pin header , On board Intel 82547EI to support Gigabit Ethernet LAN, Optional Intel 82562ET 10/100Mb LAN and Hi-Speed USB 2.0 high speed I/O interfaces.
Specification
Feature Description
Form Factor Full-size PICMG-bus CPU Card / Slot PC, Supports PICMG version 1.0 (Rev. 2.0) PCI version 2.0 compliant, Support ISA 64mA high drive capacity with TI 245 buffer
CPU Supports Intel Pentium 4 Northwood/Prescott CPU with 400/533/800Mhz FSB frequency, Support Intel Hyper-Threading Technology
Memory 2x184 pin DDR DIMMs to support up to 2.0GB DDR SDRAM Supports bandwidth up to 3.2GB/s(DDR400) for Single Channel mode and 6.4GB/s (DDR400) in Dual Channel mode. Supports non ECC DIMMs
Chipset Intel 82865G & 82801EB
Watchdog Timer 256-level generates NMI or system reset programmable watchdog timer
Real Time Clock Intel ICH5 integrated RTC with onboard lithium battery
Power Manegement ACPI 1.0 compliant, supports power saving mode with ATX PSU
Serial ATA Supports two Serial ATA connectors, data transfer rates up to 150MB/s
PCI Enhanced IDE Supports two IDE channels & up to four IDE drivers, Supports “Ultra DMA 33/66/100”
VGA Interface Intel 82865G GMCH built-in 256bit 2D/3D VGA controller, Dynamic vedio memory up to 64MB, Supports one external D-sub 15-pin connector & one internal 15-pin header
LAN Interface On board Intel 82547EI to support Gigabit Ethernet LAN, Optional Intel 82562ET 10/100Mb LAN
Audio Interface Intel ICH5 built-in AC97 3D audio controller with ALC201A, with CD in, Line in, Mic. In,Speaker out
SCSI Interface On Board LSI53C1030 to support Dual Channel Ultra-320 SCSI The first Channel is supported with one 68-pin wide SCSI connector. The Second channel is supported with one 68-pin & one 50-pin SCSI connectors
Multi-I/O Port 1 Floppy connector, 1 Printer port, 2 RS232 port, 1 SIR connector, 4 USB 2.0 1 Y-type cable to support PS2 Keyboard & PS2 mouse, 1 AT keyboard connector
Mini AGP port Provide the capable of driving an ADD card to support LVDS/TMDS/TV/HDTV devices Provide the capable of drive an Mini-AGP card to support AGP 8X/4X graphic card
Solid State Disk Onboard Compact Flash Type-II socket on IDE1
Environment +5V & +12V DC input from PICMG backplane One AT 4-pin power connector, Additional +12V on 4-pin connector for Pentium 4 PSU Board Dimension: 338 x 122 mm (L x W) Operation Temperature: 0 ~ 60oC (32 ~ 140oF)
公司名称: BESDE technology (shanghai) co.,ltd.
电  话: 021-68316055 / edjiang
传  真: 021-68316057
地  址: (上海市)上海洪山路501弄30号
邮  编: 200126
主  页: http://WWW.BESDE.COM
  • cpci(cSP-7001 Series)
  • cpci(cPCIS-3300)
  • cpci(cPCIS-3330)
  • 工控机(ultra600)
  • 工控机(fw-1500)
  • 工控机(fw-1800)
  • 工控机(fw-2000)
  • 工控机(Ultra100)
  • 工控机(Ultra200)
  • 工控机(Ultra400)
  • 更多产品...
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
