2U Compact Industrial Computer Chassis Features 2U rackmount design in depth of 450mm (AX61222TP)/475mm(AX61220TP) PICMG SBC structure with 5 free slots for expansion Front-accessible one 5.25", one slim-line CD-ROM, one 3.5" drive, max. two internal 3.5" drives Installed ATX12V 250W power supply (optional 300W or with PFC) Optional redundant PS and web-enabled system monitoring module (only AX61220TP) 2U工业机箱 深度分别AX61222TP 450mm / AX61220TP 475mm 支援PCIMG架构 可以扩展5个插槽 前窗一个5.25",一个3.5"一个超薄光驱 驱动器架 两个内置3.5"驱动器架 标配250W电源(可选300W或选支援PFC) 可选冗余电源和系统侦测模块(只适用AX61220TP) |
