产品介绍: |
Wrist Rest Track Ball Features Compatible with IBM™ PC XT, AT PS/2 Hardware Resolution: 400 dpi Tracking Speed: 500mm/sec Encoder: Opto-Mechanical Switch: 1 million cycle life Total Current: Less than 8mA Baud Rate: 1200 bps Dimensions (W x D x H): 12.4" (316mm) x 2.4" (60mm) x 1.4" (35mm) 手腕式轨迹球 系统规格: 兼容IBM PC XT,AT PS/2 硬件定义:400 DPI 跟踪扫描:500MM/SEC 译码器:光电-机械 总电流:8MA 波特率:1200BPS 尺寸(长×宽×高): 12.4”(316MM)×2.4”(60MM)×1.4”(35mm) |
