产品介绍: |
Mini PCI Fast Ethernet Module Features Form Factor: Mini PCI Type III 124-pin interface Controller: Intel® 82551QM (10/100Mbps) Connector: One RJ-45 port Mechanical Requirements: Two fixing holes for anti-vibration EMI Requirements: · CE · FCC class A compliance Dimensions (W x D): 2.36" (60mm) x 2.3" (58.35mm) Accessories: · One Ethernet bracket · One utility CD · One screw & standoff pack MINI PCI 快速以太网模块 系统规格 要素:MINI PCI TYPE-III 124-PIN界面。 控制器:INTEL 82551QM(10/1000MBPS) 连接器:1个RJ45 机械要求:2个抗振动的固定孔。 EMI要求:CE,FCC种类. 尺寸(长×宽×高): 2.36”(60MM)X2.2”(55.8MM) 附件: 1X以太网支架 1XCD 1X螺丝钉&有支架的包装盒 |
