产品介绍: |
Mini PCI 1394 Module Features Form Factor: Mini PCI Type III 124-pin interface PCB layers: 4 layers Controller: T1 TSB43AB23 IEEE 1394a controller Connector: Three IEEE 1394 ports Mechanical Requirements: Two fixing holes for anti-vibration EMI Requirements: · CE · FCC class A compliance Accessories: · One IEEE 1394 bracket · SBC master CD for drivers · One screw & standoff pack MINI PCI 1394模块 系统规格 要素:MINI PCI TYPE-III 124-PIN界面。 PCB 层:4层 控制器:T1 TSB43AB23 IEEE 1394A控制器. 连接器:3个 IEEE 1394连接器. 机械要求:2个抗振动的固定孔。 EMI要求:CE,FCC种类. 尺寸(长×宽×高): 2.36”(60MM)X2.2”(55.8MM) 附件: 1X1394支架 1×SBC驱动CD 2X螺丝钉&有支架的包装盒 |
