| 产品名称: |
超低价供应研华ADAM-4017
| 型 号: |
ADAM-4017 |
| 价 格: |
| 品 牌: |
产品介绍: |
8路模拟量输入模块 主要特点 通道:6路差分,两路单端 输入类型: mV, V, mA 采样速率:10采样点/秒
内容介绍
The ADAM-4017 is a 16-bit, 8-channel analog input module that provides programmable input ranges on all channels. This module is an extremely cost-effective solution for industrial measurement and monitoring applications. Its opto-isolated inputs provide 3000 VDC of isolation between the analog input and the module, protecting the module and peripherals from damage due to high input-line voltages. ADAM-4017 offers signal conditioning, A/D conversion, ranging and RS-485 digital communication functions. The module protects your equipment from ground loops and power surges by providing optoisolation of A/D input and transformer based isolation up to 3000 VDC. The ADAM-4017 uses a 16-bit microprocessor-controlled sigma-delta A/D converter to convert sensor voltage or current into digital data. The digital data is then translated into engineering units. When prompted by the host computer, the module sends the data to the host through a standard RS-485 interface.
| 关 键 词: | ADAM-4017,, ,, |
