产品名称: 气动平衡吊平衡器/INGERSOLL
型  号: (BA)单一平衡控制器 (BA) single balance controller
产品介绍: 气动平衡吊平衡器/INGERSOLL
Pneumatic balance suspending machine-- INGERSOLL
50-2000磅(22-909公斤)能力 50-2000 pound (22-909kg) capacity
物流技术后面蕴藏的力量 the contained power after the goods current
要满足当今物流应用的需求,需要一种与操作者互动配合的人机工程学起重装置的帮助。平衡吊提供了起重解决方案,通过浮动和固有的安全特性满足这些要求。
For satisfying the demands of the goods current apply on nowadays , and there need a help of the people-human engineering suspending setting that matched with the operation . The balance suspending offered a suspending solved scheme , and the demands satisfied through the suspending and the fixed safety .
平衡吊的优点 the excellence of the balance suspending machine
定位精确、无应力浮动特点能使双手自由地提起、降下和移动载荷物,实事上无阻力,不再有“升降机控制”命中和不命中定位的问题。
Rising , falling and moving the loading goods by hands through the precise position , without float power characteristic , and there is no resistance in fact , and precise problem of the “rise-fall machine control “ won’t be occurred .
调节简单——能完全接触到气流校准控制器,从而能快速方便地调节浮动装置。
Adjusted simply ---- get to the air current adjust controller entirely , so that adjusting the float installation quickly and easily .
耗气量低——每个工作循环大约需要1/8CFM(比气动葫芦少50倍),这表示能源成本很低。
Lower consume air ------ there need about 1/8 cfm of the every work cycle (less 50 times than pneumatic cucurbit ) , that means decreased the cost of the energy .
清洁无油的运行——预润滑设计消除了空气管道润滑和油雾排放。是食品加工和清洁制造环境的理想设备。
The operation of the cleanness oil less ------ the preparation lubrication design eliminated the air piping lubrication and the oil-fog letting . It is a ideal equipment in the food processing and the cleanness surround .
坚固可靠——连续负载运行,只需最少量维护保养,平衡空气提供成本效益优良的性能。
Rigidity and reliable ------ loading operation continually , and there just need the minimum maintain , the air balance offer the better capability of the cost benefit .
(BA)单一平衡控制器:配有(BA)单平衡控制器的平衡吊是传统型弹簧平衡吊的最佳替代方案。单一能力平衡吊的平衡范围相当于10个不同能力的弹簧平衡吊的平衡范围,主要区别是该平衡吊在整个行程范围中,保持着恒定张力。
(BA) single balance controller : the balance suspending machine with (BA)single balance controller is the ideal substitute scheme of the traditional spring balance machine . The balance scope of the single capacity balance suspending machine equal the balance scope of the spring balance suspending machine with 10 units varied capacity , the main difference is this type of the balance suspending machine retained the invariableness tensile in the whole stoke scope .
适用于:suitable for :
。工具的平衡 . the balance of the tool
。悬挂焊枪 . the suspending hang welding torch
。工装夹具悬吊 . frock clamp suspending hang
公司名称: 苏州爱博平衡器有限公司
电  话: 0512 68080015 / 张先生
传  真: 0512-68086716
地  址: (江苏省)中国江苏苏州高新技术产业开发区滨河路625号
邮  编: 215011
主  页: http://www.abtch.com
  • 单梁起重机(EHB)
  • 双轨双梁起重机(ZHB)
  • 爱博单轨起重机(ESB)
  • KPK轻轨起重机
  • 板材上料机械手(VacuMaster系列起重机)
  • 象鼻子真空吸吊机(象鼻子)
  • 气动平衡吊
  • 机械手平衡吊(TDF)
  • 包装箱堆垛机械手(TDG-50)
  • 机械手平衡吊(TDC)
  • 板材上料机械手(TDB)
  • 机械手(TDA)
  • 机械手概述
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    工控电缆线,CC-Link 和PROFIBUS总线电缆
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    版权所有 中华工控网 Copyright©2009 Gkong.com, All Rights Reserved
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
