点击看大图
产品名称: 120W MINI CARPC 车载电源
型  号: 120w
品  牌: hoply
产品介绍: 产品名称:120W MINI CARPC PSU
产品型号:120Watts DC-DC ATX Power Supply
Power Ratings (Max Load = 140 Watts)
Output Max Load (A) Peak Load (A) Regulation%
5V 6A 8A +/-1.5%
3.3V 6A 8A +/-1.5%
5VSB 1.5A 2A +/-1.5%
-12V 0.05A 0.2A +/-1.5%
12V 7A 10A Switched input
At max load, forced air ventilation is required. For fanless operation de-rate the output of the 3.3 and 5V rails by ~20%. Peak load should not exceed 60 seconds.
Size: 44.5mm(L) * 20mm(W) * 30mm (H) (1U compliant)
Weight: 57gramms, including cable harness, 27 grams without cable harness.
DC-Jack: Female, panel mount, 2.5*5.5*10 mm.
Connectors
Molex 39-01-2200, two 3.5” drive power connector, 1 floppy. P4-12V 4
pin header adapter sold separately.
Overload protection
Over load protection will be effected when either of the loads (+5V &
+3.3V) exceeds > 200% Max Load.
Turn-on Delay
After turning on, at least 20 ms will be needed for the rise of +5VSB
output voltage (measured from 10% to 95%) to reach its peak.
Remote ON/OFF control
Logic level is LOW -Output voltage is enabled (PS_ON pin)
Logic level is HIGH -Output voltage is disabled (PS_ON pin)
Operating environment: Temperature: -20 to 85 degree centigrade.
Relative Humidity: 10 to 90 percent, non-condensing.
Efficiency, MTBF: 95%. MTBF=100K hours at 55Celsius.
公司名称: 合利科技有限公司
联 系 人: 熊小姐
电  话: 0755 81161925
传  真: 0755-26583455
地  址: (广东省)深圳市高新技术产业园汇景豪苑海悦阁9B
邮  编: 518057
主  页: http://www.hopely.com.cn
  • EPIA CN13000嵌入式主板(EPIA-CN13000)
  • HTPC机箱-HTPC-01(HTPC-01)
  • DC/DC电源模块(HP800)
  • 150w车载电源,ITPS DC/DC电源(150W CARPC PSU)
  • 车载PC dc/dc-ATX稳压且隔离CARPC电源
  • 防火墙嵌入式主板-EPIA-PD10000(EPIA-PD10000)
  • DOM电子硬盘(SUNDOM)
  • DOM,电子硬盘,电子盘(SUNDOM)
  • POS主板,VOD主板,机顶盒主板,NC主板(mini-itx)
  • 160W ITPS DC/DC车载电源(160w)
  • DOM,IDE,电子硬盘,电子盘,DOM电子盘,IDE电子盘(多种)
  • 车载电脑CARPC电源-高效率DC/DC电源(DC/DC)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
