Main Feature 4U 19"机架式机箱 两个系统风扇,支持CPU散热及降低组件温度 支持标准母板ATX,Micro ATX标准规格 配备PS/2 AT/ATX和迷你冗余电源 前置四个5.25"CD-ROM和一个3.5"HDD,内置两个3.5"HDD驱动盘 两个安全门(可锁)保护运行系统 前面板带两个USB接口和键盘接口 Introduction ARC-645M is a 4U-high Rack-mount industrial computer chassis designed for building storage equipment user applications. The unit supports an ATX motherboard and server board form factor. There is strong storing the equipment and supporting dual system fans. All standard computing peripherals and Add-on card can be integrated with the chassis to meet different application requirements.
