Main Feature 3U 19"机架式机箱 两个系统风扇,适用于CPU和HDD温度控制 支持标准母板ATX,Micro ATX标准规格 配备PS/2 AT/ATX 电源 前置两个5.25"CD-ROM和一个3.5"HDD 内置五个3.5"HDD驱动盘 两个安全门(可锁)保护运行系统 前面板带两个USB接口和键盘接口 Introduction ARC-635M is a 3U-high Rack-mount industrial computer chassis designed for building critical user applications. The unit supports an ATX motherboard form factor and is equipped with a PS2 ATX power supply and dual system fans. There is strong storing the equipment and supporting the space and smaller use of volume of machine case. Some standard computing peripherals and Add-on card can be integrated with the chassis to meet different application requirements.
