Main Feature 2U 19"机架式机箱 支持6槽ISA/PICMG 背板 配备PS/2 AT/ATX 400W电源 前置一个5.25"CD-ROM和一个3.5"FDD 内置一个3.5"HDD 安全门(可锁)保护运行系统 前面板带一个键盘接口 Introduction ARC-620 is a 2U-high rack-mount industrial computer chassis designed for space-limited applications. The unit supports 6-slot butterfly backplane and is equipped with a PS2 ATX power supply. The chassis provide the space efficiency required applications such for CT and networking. All standard computing peripherals and Add-on card can be integrated with the chassis.
