Main Feature 支持高性能全长CPU卡和6槽PICMG无源底板 支持壁挂式或台式应用 前置一个5.25" CD-ROM 、3.5" FDD和内置两个3.5" HDD 易于安装的滚珠轴承散热风扇和易于更换的过滤器 带一条固定板卡用的向下固定条 Introduction The AEC-206 comes with a 6-slots PICMG or an ISA backplane to maximize the high performance of Pentium 4 full-size CPU Card. An ATX 12V power supply up to 300W is also equipped dedicated to Pentium 4 CPU Card. Inside this chassis, you can attach one 5.25" CD-ROM, one Floppy and TWO 3.5" Hard disk drives for high data storage capacity. Despite of the high density inside, you never worry about the overheat of the chassis because we attach one 12x12 system fan in the chassis front cover for excellent heat dissipation. On the front panel of AEC-206, two LED indicators indicate the power and HDD activity. The front panel also provides two switches for system reset and power ON/OFF. And two USB ports beside the LED indicators provide easy-to-access interface for your various USB peripherals. At the bottom of AEC-206, one set of wall-mount kit reserves the flexibility for wall-mount application.
