产品介绍: |
主要特点: 全球通用全范围交流输入电压, 功率因素校正:0.98at115VAC;0.94at230VAC, 有短路、过载保护和过电压保护, 国际安规认证:UL/CUL/TUV/CB/CE, 自然风冷(100W), 直流风扇强制风冷(150W), 100%满载老化测试, 3年免费质保 主要指标: 交流输入电压范围:90~264VAC/127~370VDC 交流冲击电流: 45A/230V 直流调整范围:通道1:额定输出电压的-5~+10% 过载保护:过电流限制105%~150%,自动侦测,自动复原 过电压保护:通道1:5.75~6.75额定输出电压 初始化、上升、保持时间:230VAC满载时800ms,60ms,20ms 绝缘特性:输入端与输出端间:3KVAC,输入端与外壳间:1.5KVAC1分钟 工作温度:-10~60℃(参考输出曲线) 安全标准:通过UL1950,TUV,EN60950认证 EMC标准:EN550022 class B,EN61000-3-2,3 EN61000-4-2,3,4,5,6,11,ENV50204 接线方式:7.5mm带盖端子排 外形尺寸:199×99×50mm 型号 输出 容差 纹波 效率 最大功率 QP-100B 5V,2.0~10A ±3% 120mV 77% 100W 12V,0.3~4.0A ±8% 150mV -5V,0.0~1.0A ±5% 200mV -12V,0.0~1.0A ±8% 150mV QP-100C 5V,2.0~10A ±3% 120mV 77% 103W 15V,3.0~3.0A ±8% 180mV -15V,0.0~1.5A ±8% 200mV -5V,0.0~1.0A ±5% 150mV QP-100D 5V,2.0~10A ±3% 100mV 78% 101W 12V,0.3~3.0A ±3% 150mV 24V,0.3~2.0A ±6% 150mV -12V,0.0~1.0A ±5% 150mV QP-100F 5V,2.0~10A ±3% 100mV 78% 101W 15V,3.0~3.0A ±3% 150mV 24V,0.3~2.0A ±6% 150mV -15V,0.0~1.0A ±5% 100mV QP-100-3A 5V,2.0~10A ±3% 100mV 74% 99W 3.3V,0.0~10A ±3% 150mV +12V,0.3~3.0A ±6% 150mV -5V,0.0~1.0A ±5% 100mV QP-100-3B 5V,0.0~10A ±3% 120mV 74% 100W +3.3V,0.0~10A ±3% 150mV +12V,0.3~3.0A ±6% 200mV -12V,0.0~1.0A ±5% 150mV QP-100-3C 5V,2.0~10A ±3% 120mV 75% 100W +3.3V,0.0~10A ±3% 180mV +15V,0.3~2.0A +8,-6% 200mV -15V,0.0~1.0A ±5% 150mV QP-100-3D 5V,2.0~10A ±3% 120mV 75% 100W +3.3V,0~10A ±3% 180mV +24V,0.3~2.0A ±6% 200mV -12V,0.0~1.0A ±5% 150mV 更详细资料请查本公司网站或电话咨询
