产品介绍: |
主要特点: 全球通用全范围交流输入电压, 功率因素校正:0.98at115VAC;0.95at230VAC, 通道4为隔离输出,可选择+/-极性, 通道1,2可调输出电压的-5~+10% 通道1,2有内置远端侦测 有供电正常/失败信号输出(选件) 有短路、过载保护和过电压保护,超温保护, 国际安规认证:UL/CUL/TUV/CB/CE, 直流风扇强制风冷, 134KHz固定开关频率, 100%满载老化测试, 3年免费质保 主要指标: 交流输入电压范围:90~264VAC/127~370VDC 交流冲击电流:冷启动,45A/115V & 230V 直流调整范围:通道1,2:额定输出电压的-5~+10% 过载保护: 105%~135%,恒流,自动复原 初始化、上升、保持时间:230VAC满载时800ms,50ms,16ms 供电正常/失败信号:10ms/1ms 绝缘特性:输入端与输出端间:3KVAC,输入端与外壳间:1.5KVAC1分钟 工作温度:有风扇:-10~60℃(参考输出特性曲线) 安全标准:通过UL1950,TUV EN60950认证 EMC标准:EN550022 class B,EN61000-3-2,3 EN61000-4-2,3,4,5,6,8,11,ENV50204 接线方式:9P/9.5mm带盖端子排 外形尺寸:230×115×50mm 重量及包装:1.1公斤/只;每箱12只/15公斤/0.0238立方米 型号 输出 容差 纹波 效率 最大功率 QP-200D 5V,3.0~20A ±3% 100mV 75% 203W 12V,0.0~7.0A ±3% 150mV 24V,0.4~6.0A +10,-6% 150mV ±12V,0.0~1.0A ±6% 150mV QP-200F 5V,3.0~20A ±3% 100mV 75% 202W 15V,0.0~6.0A ±3% 150mV 24V,0.4~6.0A +10,-6% 150mV ±15V,0.0~1.0A ±6% 150mV QP-200-3A 3.3V,0.0~20A ±3% 100mV 72% 200W 5V,3.0~20A ±3% 100mV +12V,0.5~8.0A +8,-10% 150mV ±5V,0.0~1.0A ±6% 150mV QP-200-3B +3.3V,0.0~20A ±3% 100mV 72% 205W 5V,3.0~20A ±3% 100mV +12V,0.5~8.0A +8,-10% 150mV ±12V,0.0~1.0A ±6% 150mV QP-200-3C +3.3V,0.0~20A ±3% 100mV 72% 210W 5V,3.0~20A ±3% 100mV +15V,0.5~7.0A +10,-6% 150mV ±15V,0.0~1.0A ±6% 150mV QP-200-3D +3.3V,0~20A ±3% 100mV 74% 204W 5V,3.0~20A ±3% 100mV +24V,0.4~6.0A +10,-6% 150mV ±12V,0.0~1.0A ±6% 150mV QP-200-3E +3.3V,0~20A ±3% 100mV 74% 206W 5V,3.0~20A ±3% 100mV +24V,0.4~6.0A +10,-6% 150mV ±15V,0.0~1.0A ±6% 150mV 更详细资料请查本公司网站或电话咨询
