产品名称:GIGA技嘉MINI-ITX主板
产品型号:GIGA MINI-ITX Processor VIA C3 CPU800 or 1Ghz
Operating System Embedded XP.Linux.Wince .NET 4.2
Memory One 184 pins DDR DIMM Sockets for 128/256/512MB
Video Internal 8X AGP,8/16/32/64MB share system memory
System BIOS 256KB Flash ROM ,AWARD BIOS
North Bridge VIA CLE166(VT8623)
South Bridge VIA VT8235
LAN Realtek RTL8100C support 10/100 Mb LAN(Compatible with Gbit LAN 8110S)
Super I/O VIA VT1211
AC''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''97 CODEC Realtek ALC655 6 channel
DOC BGA G3 DOC 32/64/128/256MB(Currently 32/64MB,future 128/256MB)
PMU ACPI 1.0B Compliance
Power ATX
Physical 170mm(L) * 170mm(W)
I/O Ports Rear: One PS2 Mouse +Keyboard connector
One 15 pin D-sub for VGA
One 2 port USB 2.0 +1 RJ-45 10/100Mb LAN
ONE 25 pins D-sub connector for parallel port
Two 9 pin connector for COM port
One COM port+Line-out+Line-in+Mic jack
On Board connectors
One standard PCI slot
Two 2*20 pin IDE connector(IDE1 with pin 20 with 5V power,IDE2 for standard IDE)
One 2*5pin front panel connector
Two2*5 pin pinheader for USB2.0
One 3 pin wake on LAN connector
One 2*5 pin Front Audio connector for speaker & microphone
Two 3 pin fan connector
One 20 pin connector for ATX
EMI/Safety Fcc class B, CE, UL(in TA1 chassis)
