点击看-PCI-E 并口卡-大图
产品名称: PCI-E 并口卡
型  号: HHL4408A
价  格:
4408A
1 Port Parallel PCI Express Board
Product Information
SUNIX PCI Express Parallel communication board meets the new interface standard for expansion board. It is compatible with PCI Express x1, x2, x4, x8 amd x16 lane Bus, enabling this board to be installed in any PCI Express capable PC system. Majority of today''''s motherboard no longer come with parallel port, with SUNIX PCI Express parallel board, users can add or expand 1 port of parallel interface on their system, allowing them to connect their parallel devices. SUNIX PCI Express parallel board is the advanced and high efficient solution for commercial and industrial automation applications.
FEATURES
  • Express one IEEE1284 Parallel ports on system
  • Designed to meet PCI Express Bases Specification Revision 1.1
  • Supports x1, x2, x4, x8, x16 (lane) PCI Express Bus connector keys
  • High speed SUN1888 Parallel controller on-board
  • Support IEEE 1284-1994 parallel port standard
    ECP(Enhance Capacity Port) / EPP(Enhance Parallel Port)
    SPP(Standard Parallel Port) / BPP(Bi-direction Parallel Port)
  • Certified by Microsoft WHQL, CE, FCC approval
  • Support DOS, Linux, Microsoft Windows 2000, XP and 2003
  • Ready for the Intel and AMD 32 / 64-bit CPU system
    PCI-Express Tutorial
    PCI Express is the next revolution I/O interconnects standards that will deliver the bandwidth and features required by PCs, cosumer electronics and communications devices. The architecture is a cost-effective, low-pin count, and point-to-point technologies offering maximum bandwidth, reducing cost and design complexity and enabling smaller form factors. Single-lane (or x1) PCI Express link has potential transfer rates of 2.5 Gbps by two pairs of wires connection. This differs from existent PCI Bus architectures that used a shard, parallel bus architctures.
    Specifications
    Parallel Communication
    Interface IEEE1284
    BUS PCI Express one lane (x1) Bus
    Controller SUNIX SUN1888
    No. of Port 1 port
    Port type Pin Header to DB25F
    IRQ & IO Assigned by System
    FIFO 32 byte hardware FIFO
    Speed 2.7 Mbps
    Mode ECP / EPP / SPP / BPP
    Driver Support
    Microsoft Windows 2000 / XP/2003 (32 / 64-bit)
    Linux Linux 2.4x / 2.6x
    Regulatory Approvals
    Hardware CE, FCC
    Software WHQL
    Operation Environment
    Operation Temperature 0 to 60°C
    Operation Humidity 5 to 95% RH
    Storage Temperature -20°C to 85°C
    Item 4408A
    Port 1
    BUS PCI-E x 1
    PCB Connector DB25F
    Bracket Space 1
    Dimensions 120 x 94 mm
    Bracket Std. 121 mm
    Application Commercial Automation
    Pin Assignment
    Application
  • Package
    4408A PCI Express Multi-IO Board
    Pin Header to DB25F Connector Bracket set
    User''''s Manual and Software CD ROM
    Quick Installation Guide
    关 键 词:4408A, PCI-E并口卡, 并口卡
    公司名称: 北京海华联机电技术有限公司
    联 系 人: 刘燕
    电  话: 010 82613035
    传  真: 010-82611567
    地  址: (北京市)海淀区海淀路19-1号中成大厦307室
    邮  编: 100080
    主  页: http://www.bjhhlc.com
  • 笔记本二代Express转双串口卡(HES-02)
  • 串口卡SUNIX 4037A(SUNIX 4037A)
  • RS-232串口卡4037A(4037A)
  • 并口卡(SUNIX CBP0020)
  • ISA 工业多并口卡(SUNIX 4017A)
  • 多功能卡4079A(SUNIX 4079A)
  • PCI-E串口卡4437A(4437A)
  • PCI-E并口卡(SUNIX 4408A)
  • 64位并口卡(SUNIX 4018A)
  • PCI4口RS-232串口卡SUNIX 4056A(4056A)
  • 笔记本二代Expresscard 串并口卡(HEPS-01)
  • 笔记本串并口一体卡HCPS-01(HCPS-01)
  • 8串口RS-232/422/485PCI串口卡CP-118U/CP-138U(CP-118U/CP-138U)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
