主要产品为:
KD-2300 MULTI-VIT MULTI-PURPOSE POSITION SENSING 测量范围0.020-2.0英寸,精度0.01%,线性度±0.5-±1%,频响50KHZ;
KD-2440 HIGH-PRECISION PROXIMITY MEASURING SYSTEM 精度可到12微英寸,校准容易,低能耗,尤其适用于材质为铁的测量,输入电压12或24VDC,极低的开关磁滞;
SERIES 8000-MODULAR RACK-MOUNTED MULTICHANNEL POSITION SENSING 精度高于10微英寸,可选配16只标准传感器,扩展模块可提供总合/比照,双设定点,电压和电流转换,和动态测量;
SMU-9000/9200 FLEXIBLE SYSTEM FOR OEM APPLICATION 信噪比为1PPM,精度0.1%,能耗低,每通道低于40MW;
KD-5100 DIFFERENTIAL SUPER HIGH PRECISION 精度可达纳米级,高灵敏性 10V/MIL(394mV/µm);
DIT-5200 DIFFERENTIAL IMPEDANCE TRANSDUCER 纳米级精度,热稳定性 ±0.03% FS/°C,零负荷时±0.005% FS/°C.,线性度0.1%;
KµDA - Kaman''s micro digital advantage 按钮校准,操作方便,数字过滤,快速取样,达10000/秒,操作温度可达200°C,支持RS232和RS485端口;
GageProx™- Fixed-gain linear inductive analog proximity sensors developed specifically for metalforming and low-cost applications 尤其适用于含铁材质,防护等级IP67;
ThreadChecker™ - An application-specific version of GageProx designed to check thread presence 两种规格传感器 4MM和5.8MM,IP67防护;
Sensors - Advanced family of high-precision position sensors 测量范围0.002—2.5英寸,不锈钢或PEEK外壳,环保型设计,高速模拟量或数字量信号调节器。
