| 产品名称: |
USBDAQ-1608HS-2AO
| 型 号: |
1608HS-2AO |
| 价 格: |
0.00 |
| 品 牌: |
MCCdaq |
产品介绍: |
产品应用 多功能, 8 通道, 16 位, 同时采样, 基于USB 的设备提供的模式I/O 和数字式I/O
产品特点 Measurement Computing’s powerful new USB-1608HS-2AOS offers high speed and true simultaneous sampling for hundreds less than comparable offerings from the competition.
The USB-1608HS is a USB 2.0 high-speed devices supported under popular Microsoft® Windows® operating systems. The USB-1608HS-2AO is fully compatible with both USB 1.1 and USB 2.0 ports.
主要参数 >> Eight analog input channels—differential or single-ended >> True simultaneous sampling (1 A/D converter per input) >> 16-bit resolution >> 250 kS/s per channel (2 MS/s aggregate) >> 16 digital I/O bits—LED status indicators >> 32-bit event counter >> Analog trigger input >> Two 16-bit analog output channels
| 关 键 词: | USBDAQ 数据采集 |
