点击看-USBDAQ-1616HS-大图
产品名称: USBDAQ-1616HS
型  号: 1616HS
品  牌: MCCdaq
产品介绍: 产品应用
  USB 1-MHz, 16-bit 位多功能模块
  产品特点
The USB-1616HS delivers outstanding performance and a wide variety of analog input, and digital and frequency I/O in one compact and low-cost package. The simple plug-in AI-EXP48 expansion module can quadruple the analog input channel count of any of the USB-1616HS series modules.
Software included with the series is extensive, including the new TracerDAQ® 2.0, a full-featured, out-of-the-box data logging, viewing, and analysis application, plus Universal Library™, UL for LabVIEW™, and InstaCal™ installation, calibration, and test utility.
  主要参数
  • 1-MHz/16-bit A/D converter
  • 8 differential or 16 single-ended analog inputs, with 7 programmable input ranges from ±100 mV to ±10 V full scale
  • Simple expansion (via AI-EXP48 option) results in 32DI/64SE analog inputs
  • Any analog input can measure voltage or thermocouples—any TC type on any channel
  • Over-sampling mode, including line-cycle rejection for ultra stable TC and low-level voltage measurements, even in the presence of AC power line noise
  • 24 digital I/O
  • 4 counter inputs capable of measuring frequency, period, pulse width, or quadrature encoders up to 20 MHz
  • 2 timer outputs
  • Synchronous I/O, where all analog inputs, digital I/O and counter/timer I/O can occur synchronously, resulting in precise time correlation between all I/O
  • Low latency control outputs capable of responding to inputs in as fast as 2 µs
  • Includes external power supply with US cable
    (European cable available separately)
  • Also available:
    • USB-1616HS-2 adds two analog outputs
    • USB-1616HS-4 adds four analog outputs
    • AI-EXP48 expansion module quadruples the number of AI channels
  • 关 键 词:USBDAQ 数据采集 1616HS
    公司名称: 嘉兆科技(深圳)有限公司
    联 系 人: 余卫荣
    电  话: 0755 83760007
    传  真: 0755-83761816
    地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
    邮  编: 518033
    主  页: http://www.corad.com.cn/
  • AS系列单通道应变放大器(NEC三荣)(AS系列)
  • RA2300, RA2800数字示波记录仪( RA2300, RA2800)
  • 数据采集器-DaqLab/2005(DaqLab/2005)
  • USBDAQ-USB-5201(USB-5201)
  • (Sorensen)600W 可程式控制电源供应器-DLM 系列(DLM 系列)
  • RF-DTMB便携式数字/地面国标信号射频/实时码流分析(RF-DTMB)
  • 汽车传导抗扰度测试仪(AR)(-)
  • CMMB (STiMi)信号源 - CMG2000(CMG2000)
  • 高速数字模式发生器(DPG)-Aeroflex(DPG)
  • YellowFin WiMAX 分析仪(BVS)(YellowFin WiMAX)
  • CS80000系列宽带通道模拟器(BCS)-Aeroflex(CS80000)
  • CS35000F系列宽带信号分析和记录仪(BSA)-Aeroflex(CS35000F)
  • CS25000F系列宽带信号和环境模拟发生器BSG(Aeroflex)(CS25000F)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
