点击看-PCIDAQ-DaqBoard/1000-大图
产品名称: PCIDAQ-DaqBoard/1000
型  号: DaqBoard/1000
品  牌: IOtech
  产品应用
  The DaqBoard/1000™ series of low cost,
  multifunction PCI boards are ideal for
  OEM or embedded applications. These
  boards are best suited to applications
  with pre-conditioned voltage signals up
  to 16 channels. For applications that
  require channel expansion or signal conditioning
  for measuring temperature,
  strain, vibration and more, consider our
  DaqBoard/2000 PCI series with its line
  of over 40 DBK signal conditioning and
  expansion options.
  The DaqBoard/1000 series offers all the
  functionality of higher priced PCI boards
  along with features not found in other
  manufacturers’ low-cost offerings including
  flexible analog inputs with 7 analog gain
  ranges, inputs configurable as differential
  or single ended, 24 digital I/O lines,
  synchronous analog, digital and frequency
  I/O, and included Linux drivers.
  Software support for the DaqBoard/1000
  series includes support for Visual Studio®
  and Visual Studio® .NET, including examples
  for Visual C++®, Visual C#®,
  Visual Basic®, and Visual Basic® .NET,
  plus comprehensive drivers for
  DASYLab®, LabVIEW®, and MATLAB®.
  Also included is DaqView Out-of-the-Box™
  software for quick and easy set up and
  collection of data without programming,
  along with DaqCal™ software application
  for easy user calibration. Linux support is
  also available.
  产品特点
• 16-bit, 200-kHz A/D converter
• 8 differential or 16 single-ended analog inputs (software selectable per channel)
• Up to four boards can be installed into one PC
• 100% digital calibration
• 512 location channel/gain FIFO
• DMA bus mastering for synchronous analog I/O, digital I/O, and counter inputs
• Trigger modes include digital and software, with <5 µs latency
• Virtually infinite pre-trigger buffer
• Two 16-bit, 100-kHz analog outputs with infinite continuous waveform output capability (model /1000 only)
• 24 digital I/O lines, can be scanned synchronously or asynchronously with analog and frequency inputs
• Four counter/pulse input channels can be scanned synchronously or asynchronously with analog and digital inputs
• Two timer/pulse output channels
Software
•DaqView Out-of-the-Box software application for effortless data logging and analysis
•Comprehensive drivers for DASYLab®, MATLAB®, LabVIEW®, Visual C++®, Visual C#®,
•Visual Basic®, and Visual Basic® .NET
•DaqCal software application for easy user-calibration
  主要参数
请索取产品DATASHEET
  产品证书
CE
关 键 词:PCI 数据采集
公司名称: 嘉兆科技(深圳)有限公司
联 系 人: 余卫荣
电  话: 0755 83760007
传  真: 0755-83761816
地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
邮  编: 518033
主  页: http://www.corad.com.cn/
  • AS系列单通道应变放大器(NEC三荣)(AS系列)
  • RA2300, RA2800数字示波记录仪( RA2300, RA2800)
  • 数据采集器-DaqLab/2005(DaqLab/2005)
  • USBDAQ-USB-5201(USB-5201)
  • (Sorensen)600W 可程式控制电源供应器-DLM 系列(DLM 系列)
  • RF-DTMB便携式数字/地面国标信号射频/实时码流分析(RF-DTMB)
  • 汽车传导抗扰度测试仪(AR)(-)
  • CMMB (STiMi)信号源 - CMG2000(CMG2000)
  • 高速数字模式发生器(DPG)-Aeroflex(DPG)
  • YellowFin WiMAX 分析仪(BVS)(YellowFin WiMAX)
  • CS80000系列宽带通道模拟器(BCS)-Aeroflex(CS80000)
  • CS35000F系列宽带信号分析和记录仪(BSA)-Aeroflex(CS35000F)
  • CS25000F系列宽带信号和环境模拟发生器BSG(Aeroflex)(CS25000F)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
