点击看-PCIDAQ-DaqBoard/2000-大图
产品名称: PCIDAQ-DaqBoard/2000
型  号: DaqBoard/2000
品  牌: IOtech
产品介绍:   产品应用
  16 位, 200 -kHz PCI 接口16 模拟输入, 二16 位, 100-kHz 模拟输出, 40 数字式I/O 、四个16 位柜台, 和二个16 位定时器; 包括DaqView 和DaqCal 软件; 全面支持为DASYLab, MATLAB, LabVIEW, 视觉C++, 视觉C #, Visual.basic, 和Visual.basic NET.
  产品特点
  The DaqBoard/2000™ series sets the price/performance benchmark for highspeed,multifunction plug-and-play data acquisition for PCI bus computers. The DaqBoard/2000 series hardware design offers all of the features normally found
on significantly more expensive boards, including 16-bit, 200-kHz A/D, 100% digital calibration, bus mastering, two or four 16-bit, 100-kHz D/A converters, 40 digital I/O lines, four counters, and two timers.
  DaqBoard/2000 series is supported by a growing family of over 40 signal conditioning and expansion options, offering signal conditioning for thermocouples,
RTDs, accelerometers, isolation, high-voltage,strain gages, and much more. Up to
528 channels of analog and digital I/O can be accessed using one DaqBoard/2000,
while maintaining the 5 µs per channel rate. Up to four DaqBoard/2000s can be installed into one PC.
  Software support for the DaqBoard/2000 series includes support for Visual Studio®and Visual Studio® .NET, including examples for Visual C++®, Visual C#®,
Visual Basic®, and Visual Basic® .NET, plus comprehensive drivers for
DASYLab®, LabVIEW®, and MATLAB®. Also included is DaqView Out-of-the-Box™
software for quick and easy set up and collection of data without programming,along with DaqCal™ software application
for easy user calibration. Linux support is also available.In total, the DaqBoard/2000 series sets the industry standard for plug-and-play PCI data acquisition.
  主要参数
• Three DaqBoard/2000 Series PCI boards are available
• 16-bit, 200-kHz A/D converter
• 8 differential or 16 single-ended analog inputs (software selectable per channel)
• Expandable up to 256 analog input channels, while maintaining 200 kHz (5 µs per channel) scan rate
• Up to four boards can be installed into one PC for up to 1024 analog input channels
• 100% digital calibration
• 512 location channel/gain FIFO, capable of scanning all channels, including 256 analog expansion channels and digital/counter channels, at 5 µs per channel
• DMA bus mastering for synchronous analog I/O, digital I/O, and counter inputs
• Trigger modes include analog, digital, and software, with <5 µs latency
• Virtually infinite pre-trigger buffer*
• Up to four 16-bit, 100-kHz analog outputs with infinite continuous waveform output capability*
• 40 digital I/O lines, can be scanned synchronously or asynchronously with analog inputs
• Digital I/O is expandable up to 272 lines, including optional isolation and relay closure
• Four counter/pulse input channels can be scanned synchronously or asynchronously with analog inputs
• Two timer/pulse output channels
  产品证书
CE
关 键 词:PCI 数据采集
公司名称: 嘉兆科技(深圳)有限公司
联 系 人: 余卫荣
电  话: 0755 83760007
传  真: 0755-83761816
地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
邮  编: 518033
主  页: http://www.corad.com.cn/
  • AS系列单通道应变放大器(NEC三荣)(AS系列)
  • RA2300, RA2800数字示波记录仪( RA2300, RA2800)
  • 数据采集器-DaqLab/2005(DaqLab/2005)
  • USBDAQ-USB-5201(USB-5201)
  • (Sorensen)600W 可程式控制电源供应器-DLM 系列(DLM 系列)
  • RF-DTMB便携式数字/地面国标信号射频/实时码流分析(RF-DTMB)
  • 汽车传导抗扰度测试仪(AR)(-)
  • CMMB (STiMi)信号源 - CMG2000(CMG2000)
  • 高速数字模式发生器(DPG)-Aeroflex(DPG)
  • YellowFin WiMAX 分析仪(BVS)(YellowFin WiMAX)
  • CS80000系列宽带通道模拟器(BCS)-Aeroflex(CS80000)
  • CS35000F系列宽带信号分析和记录仪(BSA)-Aeroflex(CS35000F)
  • CS25000F系列宽带信号和环境模拟发生器BSG(Aeroflex)(CS25000F)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
