点击看-PCIDAQ-DaqBoard/2001-大图
产品名称: PCIDAQ-DaqBoard/2001
型  号: DaqBoard/2001
品  牌: IOtech
产品介绍:   产品应用
  16 位, 200-kHz PCI 数据采集卡
  产品特点
同DaqBoard/2000 一样但与四16 位, 100-kHz 模拟输出
  主要参数
  • Three DaqBoard/2000 Series PCI boards are available
  • 16-bit, 200-kHz A/D converter
  • 8 differential or 16 single-ended analog inputs (software selectable per channel)
  • Expandable up to 256 analog input channels, while maintaining 200 kHz (5 µs per channel) scan rate
  • Up to four boards can be installed into one PC for up to 1024 analog input channels
  • 100% digital calibration
  • 512 location channel/gain FIFO, capable of scanning all channels, including 256 analog expansion channels and digital/counter channels, at 5 µs per channel
  • DMA bus mastering for synchronous analog I/O, digital I/O, and counter inputs
  • Trigger modes include analog, digital, and software, with <5 µs latency
  • Virtually infinite pre-trigger buffer*
  • Up to four 16-bit, 100-kHz analog outputs with infinite continuous waveform output capability*
  • 40 digital I/O lines, can be scanned synchronously or asynchronously with analog inputs
  • Digital I/O is expandable up to 272 lines, including optional isolation and relay closure
  • Four counter/pulse input channels can be scanned synchronously or asynchronously with analog inputs
  • Two timer/pulse output channels
  •   产品证书
    CE
    关 键 词:PCI 数据采集
    公司名称: 嘉兆科技(深圳)有限公司
    联 系 人: 余卫荣
    电  话: 0755 83760007
    传  真: 0755-83761816
    地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
    邮  编: 518033
    主  页: http://www.corad.com.cn/
  • AS系列单通道应变放大器(NEC三荣)(AS系列)
  • RA2300, RA2800数字示波记录仪( RA2300, RA2800)
  • 数据采集器-DaqLab/2005(DaqLab/2005)
  • USBDAQ-USB-5201(USB-5201)
  • (Sorensen)600W 可程式控制电源供应器-DLM 系列(DLM 系列)
  • RF-DTMB便携式数字/地面国标信号射频/实时码流分析(RF-DTMB)
  • 汽车传导抗扰度测试仪(AR)(-)
  • CMMB (STiMi)信号源 - CMG2000(CMG2000)
  • 高速数字模式发生器(DPG)-Aeroflex(DPG)
  • YellowFin WiMAX 分析仪(BVS)(YellowFin WiMAX)
  • CS80000系列宽带通道模拟器(BCS)-Aeroflex(CS80000)
  • CS35000F系列宽带信号分析和记录仪(BSA)-Aeroflex(CS35000F)
  • CS25000F系列宽带信号和环境模拟发生器BSG(Aeroflex)(CS25000F)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
