产品介绍: |
产品应用
16-bit, 200-kHz A/D converter
8 differential or 16 single-ended analog inputs (software selectable per channel)
Up to four boards can be installed into one PC
100% digital calibration
512 location channel/gain FIFO
DMA bus mastering for synchronous analog I/O, digital I/O, and counter inputs
Trigger modes include digital and software, with <5 µs latency
Virtually infinite pre-trigger buffer
Two 16-bit, 100-kHz analog outputs with infinite continuous waveform output capability (model /1000 only)
24 digital I/O lines, can be scanned synchronously or asynchronously with analog and frequency inputs
Four counter/pulse input channels can be scanned synchronously or asynchronously with analog and digital inputs
Two timer/pulse output channels | |
