点击看-PCIDAQ-DaqBoard/3000-大图
产品名称: PCIDAQ-DaqBoard/3000
型  号: DaqBoard/3000
品  牌: IOtech
产品介绍:  产品应用
  The DaqBoard/3000 series provides 1-MHz sampling, synchronous multifunction I/O, analog input expansion capability, and extensive software support.
  产品特点
  The new DaqBoard/3000™ series from IOtech continues our tradition of offering the best price/performance PCI boards in the industry. The new DaqBoard/3000 series is no exception, offering 16-bit/1-MHz multifunction,synchronous I/O at substantially lower prices. This is accomplished by incorporating a high level of integration,while focusing on features that provide valuable benefits to users.
  The new DaqBoard/3000 series feature a 16-bit/1-MHz A/D converter, 16 analog input channels – user expandable to 64, up to four 16-bit/1-MHz analog outputs,24 high-speed digital I/O, 2 timer outputs,and four 32-bit counters. All analog I/O,digital I/O, and counter/timer I/O can operate synchronously and simultaneously,guaranteeing deterministic I/O timing amongst all signal types. Also unique to the DaqBoard/3000 series is a high-speed,low-latency, highly deterministic control output mode that operates independent of the PC. In this mode both digital and analog outputs can respond to analog, digital, and counter inputs as fast as 2 µs; at least 1,000 times faster than most other boards that rely on the PC for decision making.
  主要参数
• Four low-cost, 1-MHz, 16-bit multifunction PCI boards
• 8 differential or 16 single-ended analog inputs (software selectable per channel)
• User-expandable up to 64SE/32DE analog inputs including thermocouple measurements
• Four 16-bit, 1-MHz analog outputs with continuous waveform capability
• 24 high speed digital I/O lines
• Four 32-bit counter input channels with quadrature encoder capability
• Ultra low-latency control output capability (as low as 2 µs latency)
• Multiple DMA channels
关 键 词:PCI 数据采集
公司名称: 嘉兆科技(深圳)有限公司
联 系 人: 余卫荣
电  话: 0755 83760007
传  真: 0755-83761816
地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
邮  编: 518033
主  页: http://www.corad.com.cn/
  • AS系列单通道应变放大器(NEC三荣)(AS系列)
  • RA2300, RA2800数字示波记录仪( RA2300, RA2800)
  • 数据采集器-DaqLab/2005(DaqLab/2005)
  • USBDAQ-USB-5201(USB-5201)
  • (Sorensen)600W 可程式控制电源供应器-DLM 系列(DLM 系列)
  • RF-DTMB便携式数字/地面国标信号射频/实时码流分析(RF-DTMB)
  • 汽车传导抗扰度测试仪(AR)(-)
  • CMMB (STiMi)信号源 - CMG2000(CMG2000)
  • 高速数字模式发生器(DPG)-Aeroflex(DPG)
  • YellowFin WiMAX 分析仪(BVS)(YellowFin WiMAX)
  • CS80000系列宽带通道模拟器(BCS)-Aeroflex(CS80000)
  • CS35000F系列宽带信号分析和记录仪(BSA)-Aeroflex(CS35000F)
  • CS25000F系列宽带信号和环境模拟发生器BSG(Aeroflex)(CS25000F)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
