1-MHz, 16-bit PCI data acquisition board with 8DE/16SE analog inputs, 7 input ranges from 100 mV to 10V full-scale, 24 digital I/O, four counters, and two timers; includes DaqView; support for Visual Studio and Visual Studio .NET; drivers for DASYLab, MATLAB, and LabVIEW; and DaqCal.
The new DaqBoard/3000™ series from IOtech continues our tradition of offering the best price/performance PCI boards in the industry. The new DaqBoard/3000 series is no exception, offering 16-bit/1-MHz multifunction,synchronous I/O at substantially lower prices. This is accomplished by incorporating a high level of integration,while focusing on features that provide valuable benefits to users.
The new DaqBoard/3000 series feature a 16-bit/1-MHz A/D converter, 16 analog input channels – user expandable to 64, up to four 16-bit/1-MHz analog outputs,24 high-speed digital I/O, 2 timer outputs,and four 32-bit counters. All analog I/O,digital I/O, and counter/timer I/O can operate synchronously and simultaneously,guaranteeing deterministic I/O timing amongst all signal types. Also unique to the DaqBoard/3000 series is a high-speed,low-latency, highly deterministic control output mode that operates independent of the PC. In this mode both digital and analog outputs can respond to analog, digital, and counter inputs as fast as 2 µs; at least 1,000 times faster than most other boards that rely on the PC for decision making. |
