产品名称: eZ-Balance
型  号: Balance
价  格:
产品介绍:  产品应用
  Portable Machine Balancing Software for the 600 Series and ZonicBook/618E
 产品特点
  • Multiplane trial and trim balancing
  • Polar, time, and spectral displays
  • Computes and stores influence coefficients for future trim balancing
  • Vibration data can be collected by the 600 Series or ZonicBook/618E, or entered manually
  • Balancing toolkit
    - Trial weight calculations
    - Weight splitting
    - Centrifugal force
    - Stock weights
    - Weight removed
    - Unbalance tolerance
  • Balance solution can be based on multiple response points
Balance rotating machinery with eZ-Balance and the 600 Series or ZonicBook/618E. The combination of the 600 Series or ZonicBook/618E with eZ-Balance provides a powerful system for multi-plane (up to 7 planes) balancing applications. eZ-Balance computes the optimal balance weights and their locations, based on vibration data collected from the 600 Series or ZonicBook/618E. The data is displayed in a convenient Polar plot that indicates the magnitude and phase of the unbalance as well as time and spectrum data.
eZ-Balance determines a balance solution by calculating the change in vibration condition based on adding trial weights. The balance process is a series of well defined steps. The initial trial run is used to measure the as-found vibration condition. The machine is shutdown and a trial weight is added. The balance run measures the effect of the trial weight and a trial solution is calculated. A trim run is then performed to confirm the results of the trial solution. Accelerometers, velocity probes, or displacement probes may be used to measure the vibration level at each balance plane. A tachometer measures the rotation speed and provides a phase reference.
  更多产品请登录:http://www.corad.com.cn/
关 键 词:eZ, , Balance
公司名称: 嘉兆科技(深圳)有限公司
联 系 人: 余卫荣
电  话: 0755 83760007
传  真: 0755-83761816
地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
邮  编: 518033
主  页: http://www.corad.com.cn/
  • AS系列单通道应变放大器(NEC三荣)(AS系列)
  • RA2300, RA2800数字示波记录仪( RA2300, RA2800)
  • 数据采集器-DaqLab/2005(DaqLab/2005)
  • USBDAQ-USB-5201(USB-5201)
  • (Sorensen)600W 可程式控制电源供应器-DLM 系列(DLM 系列)
  • RF-DTMB便携式数字/地面国标信号射频/实时码流分析(RF-DTMB)
  • 汽车传导抗扰度测试仪(AR)(-)
  • CMMB (STiMi)信号源 - CMG2000(CMG2000)
  • 高速数字模式发生器(DPG)-Aeroflex(DPG)
  • YellowFin WiMAX 分析仪(BVS)(YellowFin WiMAX)
  • CS80000系列宽带通道模拟器(BCS)-Aeroflex(CS80000)
  • CS35000F系列宽带信号分析和记录仪(BSA)-Aeroflex(CS35000F)
  • CS25000F系列宽带信号和环境模拟发生器BSG(Aeroflex)(CS25000F)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
