产品名称: eZ-TOMAS
型  号: TOMAS
价  格:
产品介绍: 产品应用
  Machine Vibration Monitoring Software for the 600 Series, WaveBook/516E, and ZonicBook/618E
产品特点
  • Transient and Steady State rotating machinery analysis
  • Easy-to-use graphical user interface and multiple project configurations provide fast setup
  • Up to 20 kHz Analysis Frequency, with up to 25,600 lines of resolution
  • Field expandable from 8 to 56 channels
  • Overall, spectral amplitude, and phase gauges with peak hold indicators
  • Spectral limit checking, with output relays and alarm event logging
  • Limit sets for specific RPM ranges
  • Event data storage based on user defined triggers, with automatic backup
  • Rotating Machinery Analysis: Time Waveform, Orbit, ­Spectrum, Waterfall, Polar, Bode, Shaft Center Line, and Trend displays
  • Machine and Bearing Fault analysis and limit checking
  • Save/Recall display setups with up to 8 display windows, and multiple overlays
  • Integration and differentiation for acceleration, velocity, and displacement inputs
  • Harmonic, Sideband, and Peak cursors for time waveform and spectrum displays
  • Statistical analysis report with automatic limit generation
  • Generate production test cell reports
  • Export data to Excel®, UFF Type 58 Binary, or ASCII format
  • Copy/Paste graphs and data into Microsoft® applications
eZ-TOMAS is the economical solution to rotating machine monitoring and analysis. eZ-TOMAS will continuously monitor your machines. eZ-TOMAS records the change in vibration condition, and quickly provides you with the information you need to make critical decisions.
eZ-TOMAS can be quickly setup to measure rotating machine vibration data. Machine configuration and acquisition information can be copied from templates or copied from existing projects. Accessing rotating machine analysis displays are as simple as double-clicking on the desired input channel.
eZ-TOMAS checks vibration data at both alert and alarm levels. Alarm levels can either be set by you, or eZ-TOMAS can ­automatically calculate alarm levels based on past machine operation. Changes in vibration levels indicate changes in a machine’s operating condition, which are warning signs of potential machine problems.
 更多产品请登录:http://www.corad.com.cn/
关 键 词:eZ, , TOMAS
公司名称: 嘉兆科技(深圳)有限公司
联 系 人: 余卫荣
电  话: 0755 83760007
传  真: 0755-83761816
地  址: (广东省)深圳市深南中路3007号国际科技大厦2001室
邮  编: 518033
主  页: http://www.corad.com.cn/
  • AS系列单通道应变放大器(NEC三荣)(AS系列)
  • RA2300, RA2800数字示波记录仪( RA2300, RA2800)
  • 数据采集器-DaqLab/2005(DaqLab/2005)
  • USBDAQ-USB-5201(USB-5201)
  • (Sorensen)600W 可程式控制电源供应器-DLM 系列(DLM 系列)
  • RF-DTMB便携式数字/地面国标信号射频/实时码流分析(RF-DTMB)
  • 汽车传导抗扰度测试仪(AR)(-)
  • CMMB (STiMi)信号源 - CMG2000(CMG2000)
  • 高速数字模式发生器(DPG)-Aeroflex(DPG)
  • YellowFin WiMAX 分析仪(BVS)(YellowFin WiMAX)
  • CS80000系列宽带通道模拟器(BCS)-Aeroflex(CS80000)
  • CS35000F系列宽带信号分析和记录仪(BSA)-Aeroflex(CS35000F)
  • CS25000F系列宽带信号和环境模拟发生器BSG(Aeroflex)(CS25000F)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
