- Provides inspection of metal, ceramic, and hard plastic parts
- Removes the ambiguity that is common in other inspection systems
- Requires no parts preparation, making the test fast and inexpensive
- Tests parts in less than 1 seconds
- Quantifies and documents the first natural frequency for end-user comparison to final assembly resonant frequencies
IOtech’s eZ-NDT (non-destructive test) systems provide a fast and inexpensive method of 100% inspection of production parts, such as powder metal, ceramics, and composites. eZ-NDT uses acoustic analysis to identify part variations that are caused by process inconsistencies and defects. eZ-NDT systems apply acoustic energy to your part, monitor its acoustic response, and analyze its resonant frequencies. It then compares the results to the acoustic signature of a known-good part stored in its library. The test takes less than two seconds and requires no special tooling, dyes, chemicals, cleaning, magnetization, or expensive and time consuming visual inspection equipment. |
