点击看-ATX AX965Q-大图
产品名称: ATX AX965Q
型  号: AX965Q
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel&ereg uFC-LGA 775 socket Supports Quad-core Core 2 Extreme / Core 2 Duo / Pentium® D PentiumR 4 / CeleronR D with 65nm process technologyrpo
FSB
1066/800/533 MHz
BIOS
Award 16 Mb Flash ROM BIOS
System Chipset
Intel® 82Q965 GMCH / ICH8DO
I/O Chip
Winbond W83627DHG-A
System Memory
Four 240-pin DIMM sockets support up to
8 GB Dual Channel DDR2 800/667/533 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, five PCI slots
(PCI Rev. 2.2 compliant), 2 ISA
I/O
MIO
1 x UltraDMA 133/100/66/33, 8 x SATA,1 x FDD,
1 x LPT, 4 x RS-232, 1x K/B,1 x Mouse
USB
10 x USB 2.0 port
e-SATA
1 x e-SATA
IEEE-1394A
1 x 1394 (optional)tm
Display
Chipset
Intel® 82Q965 GMCH integrated Graphics
Media Accelerator 3000
Display Memory
Intel® DVMT 4.0 supports 256 MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (75Hz)
VGA/LCD Interface
PCI-E X16 VGA interface
LVDS
Through ADD2 HDMI Card
(Customized BIOS required)
DVI
Through ADD2 LVDS Card
TV-out
Through ADD2 DVI Card
DTV-out
Through ADD2 TV-out Card
Audio
Chipset
Intel® ICH8DO
AC97 Codec
ADIR AD1988 7.1-channel High Definition
Audio CODEC
Audio Interface
Mic in, Line in, CD Audio in, Line out,
6CH (6 jacks), S/PDIF
Ethernet
LAN 1
Intel® 82566DM Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 1 x Parallel port
* 1 x External SATA
* 1 x VGA port
* 1 x IEEE1394a connector (optional)
* 1 x RJ45 port
* 4 x USB 2.0/1.1
* 7.1 CH Audio I/O (6 jacks)
Internal I/O Connector
* 3 x USB connectors support
additional 6 USB ports
* 1 x 24-pin ATX Power connector
* 1 x 4-pin ATX 12V Power connector
* 1 x Floppy disk drive connector
* 1 x IDE connector for two devices
* 4 x COM connector
* 1 x CD audio in connector
* 1 x TPM connector
* 7 x SATA connectors
* 1 x Front panel audio connector
* 1 x S/PDIF Out Header
* 1 x System panel connector
* 1 x CPU Fan connector
* 2 x Chassis Fan connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
AX965Q
Intel® LGA775 Quod-core / Core 2 Extreme / Core 2 Duo / Pentium® D Pentium® 4 / Celeron® D ATX Main Board with VGA, Audio, Gb LAN, 10 USB 2.0, 1 PCI-E X16, 1 PCI-E X4, & 5 PCI
关 键 词:嵌入式 主板 AX965Q
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 886-2 2796-1888
传  真: 886-2-2794-7306
地  址: (台湾省)台北市内湖区瑞光路26巷20弄1号6楼
邮  编:
主  页: www.bcmimb.com.tw
  • Mini ITX MX800LX(MX800LX)
  • Mini ITX IX915GME(IX915GME)
  • Mini ITX IX945GME3(IX945GME3)
  • Mini ITX IX965Q(IX965Q)
  • Mini ITX IX965GME(IX965GME)
  • Mini ITX IX910GMLE-C6(IX910GMLE-C6)
  • Mini ITX IX852GM4-C6(IX852GM4-C6)
  • Mini ITX MX945GM(MX945GM)
  • Mini ITX MX945GM2(MX945GM2)
  • Mini ITX IX915GV2(IX915GV2)
  • Mini ITX MX852GM-C6(MX852GM-C6)
  • Mini ITX MX852GME(MX852GME)
  • Mini ITX MX700CN2-C10(MX700CN2-C10)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
