点击看-ATX BV945GL-大图
产品名称: ATX BV945GL
型  号: BV945GL
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel® uFC-LGA 775 socket Supports Core 2 Duo Pentium® D / PentiumR 4 / Celeron® D with 65nm process technology
FSB
1066/800/533 MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel® 82945G GMCH/ ICH7
I/O Chip
Winbond W83627EHG-A
System Memory
Four 240-pin DIMM sockets support up to 4 GB
Dual Channel DDR2 667/533 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, one PCI Express X1,
five PCI slots (PCI Rev. 2.2 compliant)
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD,
1 x LPT, 1 x RS-232, 1 x RS-232/422/485,
1x K/B, 1 x Mouse
USB
8 x USB 2.0 ports
Display
Chipset
Intel® 82945G GMCH integrated Graphics
Media Ac-celerator 950
Display Memory
Intel® DVMT 3.0 supports 224 MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (75 Hz)
VGA/LCD Interface
PCI-E X16 VGA interface
LVDS
Through ADD2 LVDS Card
(Customized BIOS required)
DVI
Through ADD2 DVI Card
TV-out
Through ADD2 TV-out Card
Audio
Chipset
Intel® ICH7
AC97 Codec
Realtek ALC 888, 7.1 CH High-Definition
Audio Codec
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Ethernet
LAN 1
Intel® 82573L Gigabit LAN
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 1 x Parallel port
* 1 x Serial port
* 1 x VGA port
* 1 x RJ45 port
* 4 x USB ports
* Audio I/O (3 jacks)
Internal I/O Connector
Internal I/O Port
* 2 x USB connectors support
additional 4 USB ports
* 1 x 24-pin ATX Power connector
* 1 x 4-pin ATX 12V Power connector
* 1 x Floppy disk drive connector
* 1 x IDE connector for two devices
* 1 x COM connectors
* 1 x Chassis intrusion connector
* 1 x CD audio in connector
* 1 x TPM connector
* 4 x SATA connectors
* 1 x Front panel audio connector
* 1 x S/PDIF out connector
* 1 x Speaker connector
* 1 x System panel connector
* 1 x 3-pin Power LED connector
* 1 x CPU Fan connector
* 1 x Chassis Fan connector
* 1 x Power Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 4.26 A, +12 V @ 10.12 A,
+3.3 V @ 722 mA (with Intel® Core 2
Duo E6400 2.13 GHz & 1 GB*2
DDR2 SDRAM)
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
12" x 9.6" (304.8 mm x 243.84 mm)
Weight
1.32 lbs (0.6 Kg)
Ordering Information
BV945GL
Intel? LGA775 Core 2 Duo / Pentium? D
Pentium? 4 / Celeron? ATX Motherboard
with VGA, Audio, Gb LAN, 2 COM,
8 USB 2.0, 1 PCI-E X16, 1 PCI-E X1,
& 5 PCI
关 键 词:嵌入式 主板 BV945GL
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 886-2 2796-1888
传  真: 886-2-2794-7306
地  址: (台湾省)台北市内湖区瑞光路26巷20弄1号6楼
邮  编:
主  页: www.bcmimb.com.tw
  • Mini ITX MX800LX(MX800LX)
  • Mini ITX IX915GME(IX915GME)
  • Mini ITX IX945GME3(IX945GME3)
  • Mini ITX IX965Q(IX965Q)
  • Mini ITX IX965GME(IX965GME)
  • Mini ITX IX910GMLE-C6(IX910GMLE-C6)
  • Mini ITX IX852GM4-C6(IX852GM4-C6)
  • Mini ITX MX945GM(MX945GM)
  • Mini ITX MX945GM2(MX945GM2)
  • Mini ITX IX915GV2(IX915GV2)
  • Mini ITX MX852GM-C6(MX852GM-C6)
  • Mini ITX MX852GME(MX852GME)
  • Mini ITX MX700CN2-C10(MX700CN2-C10)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
