点击看-Micro ATX RX915GV2-大图
产品名称: Micro ATX RX915GV2
型  号: RX915GV2
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Intel uFC-LGA 775 socket Supports Pentium D / Pentium 4 / Celeron D with 65nm process technology
FSB
800/533 MHz
BIOS
Award 4Mb Flash BIOS
System Chipset
Intel 82915GV GMCH/ ICH6
I/O Chip
Winbond(R) W83627EHG-A
System Memory
Four 240-pin DIMM sockets supports up to 4 GB Dual Channel DDR2 400/533/667 SDRAM
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring temperatures, voltages, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI Express X16, one PCI Express X1, two PCI slots (PCI Rev. 2.2 compliant)
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x SATA, 1 x FDD , 1 x LPT, 2 x RS-232, 1x K/B, 1 x Mouse
USB
8 x USB 2.0 ports
DIO
IEEE-1394A
Display
Chipset
Intel 82915GV GMCH integrated Graphics Media Accelerator 900
Display Memory
Intel DVMT 3.0 supports 128 MB video memory
Max. 3D Resolution
2048 x 1536 @ 32 bpp (85 Hz)
Dual Display
VGA/LCD Interface
PCI-E X16 SDVO interface
LVDS
Through ADD2 LVDS Card (Customized BIOS required)
DVI
Through ADD2 DVI Card (Customized BIOS required)
TV-out
Through ADD2 TV-Out Card (Customized BIOS required)
Built-in Touch Screen (Optional)
Chipset
Touch Screen Interface
Audio
Chipset
Intel ICH6
AC97 Codec
Realtek ALC888,8CH High-Definition Audio codec
Audio Interface
Mic in, Line in, CD Audio in, Line out
Ethernet
LAN 1
Realtek RTL8110SC Gigabit LAN
Ethernet Interface
1000Base-Tx Fast Ethernet compatible: Realtek RTL8110S
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x Serial port
1 x VGA port
1 x RJ45 port
4 x USB 2.0/1.1
Audio I/O (6 jacks)
Internal I/O Connector
2 x USB connectors support additional 4 USB ports
1 x 24-pin ATX Power connector
1 x 4-pin ATX 12V Power connector
1 x Floppy disk drive connector
1 x IDE connector for two devices
1 x COM connector 1 x Power LED connector
1 x Chassis intrusion connector
1 x CD audio in connector
4 x SATA connectors
1 x Front panel audio connector
1 x S/PDIF out connector
1 x System panel connector
1 x CPU Fan connector
1 x Chassis Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 4.10 A, +12 V @ 7.85 A, +3.3 V @ 1.07 A (with Intel Celeron D 3.06 GHz & 512 MB DDR SDRAM)
Power Type
ATX
Operating Temperature
0~60C (32~140F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
9.6" x 9.6" (243.84 mm x 243.84 mm)
Weight
0.88 lbs (0.4 kg)
Ordering Information
RX915GV2
Intel LGA775 Pentium D / Pentium 4 / Celeron Micro ATX Main Board with VGA, Audio, Gb LAN, 8 USB 2.0, 1 PCI-E x16, 1 PCI-E x 1, 2 PCI, & 1 PCI-E x 1
关 键 词:嵌入式 主板 RX915GV2
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 886-2 2796-1888
传  真: 886-2-2794-7306
地  址: (台湾省)台北市内湖区瑞光路26巷20弄1号6楼
邮  编:
主  页: www.bcmimb.com.tw
  • Mini ITX MX800LX(MX800LX)
  • Mini ITX IX915GME(IX915GME)
  • Mini ITX IX945GME3(IX945GME3)
  • Mini ITX IX965Q(IX965Q)
  • Mini ITX IX965GME(IX965GME)
  • Mini ITX IX910GMLE-C6(IX910GMLE-C6)
  • Mini ITX IX852GM4-C6(IX852GM4-C6)
  • Mini ITX MX945GM(MX945GM)
  • Mini ITX MX945GM2(MX945GM2)
  • Mini ITX IX915GV2(IX915GV2)
  • Mini ITX MX852GM-C6(MX852GM-C6)
  • Mini ITX MX852GME(MX852GME)
  • Mini ITX MX700CN2-C10(MX700CN2-C10)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
