点击看-Mini ITX MX700CN2-C10-大图
产品名称: Mini ITX MX700CN2-C10
型  号: MX700CN2-C10
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
VIA C7 1 GHz onboard
FSB
400/533 MHz
BIOS
Award 4Mb Flash BIOS
System Chipset
VIA CN700/VT8237R+
I/O Chip
ITE IT8712F-S
System Memory
1 240-pin DIMM socket supports up to 1 GB DDR2 533
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant)
S3
S3 Support
I/O
MIO
2 x EIDE (Ultra DMA 133), 1x LPT, 2 x SATA,
1 x K/B, 1 x Mouse, 2 x RS232
USB
6 x USB 2.0 ports
Display
Chipset
Integrated UniChrome Pro 3D/2D Graphics & Video processor
Display Memory
UniChrome Pro 3D/2D Graphics & Video processor supports up to 64 MB video memory
Resolution
1600 x 1200 @ 32 bpp (75 Hz)
Dual Display
CRT + LVDS
LVDS
VIA VT1636 supports Single channel 18/24-bit
Audio
Chipset
VIA VT8237R+
AC97 Codec
Realtek ALC653 supports 5.1 CH Audio
Audio Interface
Mic in, Line in, CD Audio in, Line out, S/PDIF
Ethernet
LAN 1
Realtek RTL8100CL 10/100 LAN
Ethernet Interface
100Base-T Fast Ethernet compatible: Realtek RTL8100CL
Back Panel I/O Port
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Parallel port
1 x VGA port
1 x Serial port
4 x USB 2.0/1.1
1 x RJ45 port
Audio I/O (3 jacks)
Internal I/O Connector
1 x USB connectors support additional 2 USB ports
1 x 20-pin ATX Power connector
2 x IDE connector for four devices 1 x COM connector
1 x CD audio in connector
2 x SATA connectors
1 x Front panel audio connector
1 x S/PDIF Out Header
1 x System panel connector
1 x LVDS connector
1 x CPU Fan connector
1 x System Fan connector
Mechanical & Environmental
Power Requirement
+5 V @ 2.48 A, +12 V @ 385mA, +3.3 V @ 4.38 A, 5Vbs@460mA (with VIA C7 1.5G & DDRII 533, 512 MB)
Power Type
ATX
Operating Temperature
0~60°C (32~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
MX700CN2-C10
VIA C7 1 GHz Mini ITX Main Board with VGA, 2-CH LVDS, 5.1 CH Audio, 10/100 LAN, PCI & 6 USB 2.0
关 键 词:嵌入式 主板 MX700CN2-C10
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 886-2 2796-1888
传  真: 886-2-2794-7306
地  址: (台湾省)台北市内湖区瑞光路26巷20弄1号6楼
邮  编:
主  页: www.bcmimb.com.tw
  • Mini ITX MX800LX(MX800LX)
  • Mini ITX IX915GME(IX915GME)
  • Mini ITX IX945GME3(IX945GME3)
  • Mini ITX IX965Q(IX965Q)
  • Mini ITX IX965GME(IX965GME)
  • Mini ITX IX910GMLE-C6(IX910GMLE-C6)
  • Mini ITX IX852GM4-C6(IX852GM4-C6)
  • Mini ITX MX945GM(MX945GM)
  • Mini ITX MX945GM2(MX945GM2)
  • Mini ITX IX915GV2(IX915GV2)
  • Mini ITX MX852GM-C6(MX852GM-C6)
  • Mini ITX MX852GME(MX852GME)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
