点击看-Mini ITX IX852GM4-C6-大图
产品名称: Mini ITX IX852GM4-C6
型  号: IX852GM4-C6
品  牌: BCM
Download
Product Spec [PDF]
Drivers & Manual
Buy Online
Get Quotation
Download Free Acrobat Reader
Free Adobe Reader
Specifications
System
CPU
Onboard Intel® Celeron® M 600MHz w/512K L2 Cache
FSB
400MHz
BIOS
Award 4 Mb Flash BIOS
System Chipset
Intel® 82852GM GMCH/82801DB ICH4
I/O Chip
Winbond W83627EHG-A
System Memory
One 184-pin DIMM socket supports up to
1 GB DDR 200/266 SDRAM
SSD
One CompactFlash Type I/II socket
Watchdog Timer
Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor
Monitoring CPU temperature, voltage, and cooling
fan status. Auto throttling control when
CPU overheats
Expansion
One PCI slot (PCI Rev. 2.2 compliant)
supports 3 PCI master
S3
S3 Support
SmartFan Control
Speed Cruise Mode
I/O
MIO
1 x EIDE (Ultra DMA 100), 4 x RS-232
USB
6 x USB 2.0
DIO
16-bit General Purpose I/O for DI and DO
Extra SATA Chips
Silicon Image Sil 3512 supports 2 SATA
with 150 MB/s transfer rate
Display
Chipset
Intel® 82852GM GMCH integrated Extreme
Display Memory
Intel® DVMT 2.1 supports up to 64 MB video memory
Resolution
CRT mode: 1600 x 1200 @ 32 bpp (85 Hz)
LCD/Simultaneous mode:
Dual Display
CRT + LVDS, or CRT + DVI
LVDS
Intel® 852GM supports Single channel 18 /
Dual-channel 36-bit LVDS
DVI
Chrontel CH7301 DVI transmitter up to
135M pixels/second
Audio
Chipset
Intel® 82801DB ICH4
Audio Code
Realtek ALC655 supports 5.1 CH Audio ( 3 jacks )
Audio Interface
Mic in, Line in, Line out
Audio Amplifer
TPA3005D2 Stereo 5 Watt per channel
Ethernet
LAN1
Realtek RTL8110SC 1000Base-T Gigabit
Ethernet Controller
Back Panel I/O Port
Back Panel I/O Port
* 1 x PS/2 Keyboard
* 1 x PS/2 Mouse
* 2 x RS-232
* 1 x VGA port
* 1 x DVI port 4 x USB 2.0/1.1
* 1 x RJ45 Port
* 5.1 CH Audio I/O (3 jacks)
Internal I/O Connector
* 1 x USB connectors support
2 USB ports
* 1 x 20-pin ATX Power connector
* 1 x IDE 40-pin connector for two devices
* 2 x COM port header
* 2 x SATA connectors
* 1 x Front panel audio connector
* 1 x Audio amplifier connector
Mechanical & Environmental
Power Type
ATX
Operating Temperature
0°~60°C (32°~140°F)
Operating Humidity
0%~90% relative humidity, non-condensing
Size (L x W)
6.69" x 6.69" (170 mm x 170 mm)
Weight
0.88 lbs (0.4 Kg)
Ordering Information
IX852GM4-C6
Intel® Celeron® Mini ITX Motherboard with
VGA, 2-CH LVDS, Audio, Gb LAN,
4 COM, 6 USB 2.0, 2 SATA, 1 PCI, CF
关 键 词:嵌入式 主板 IX852GM4-C6
公司名称: 必升科技股份有限公司
联 系 人: 陈小姐
电  话: 886-2 2796-1888
传  真: 886-2-2794-7306
地  址: (台湾省)台北市内湖区瑞光路26巷20弄1号6楼
邮  编:
主  页: www.bcmimb.com.tw
  • Mini ITX MX800LX(MX800LX)
  • Mini ITX IX915GME(IX915GME)
  • Mini ITX IX945GME3(IX945GME3)
  • Mini ITX IX965Q(IX965Q)
  • Mini ITX IX965GME(IX965GME)
  • Mini ITX IX910GMLE-C6(IX910GMLE-C6)
  • Mini ITX MX945GM(MX945GM)
  • Mini ITX MX945GM2(MX945GM2)
  • Mini ITX IX915GV2(IX915GV2)
  • Mini ITX MX852GM-C6(MX852GM-C6)
  • Mini ITX MX852GME(MX852GME)
  • Mini ITX MX700CN2-C10(MX700CN2-C10)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
