点击看-NI PCI-6225M系列多功能数据采集卡-大图
产品名称: NI PCI-6225M系列多功能数据采集卡
型  号:
品  牌: NI
产品介绍: 16-Bit, 250 kS/s, 80 Analog Inputs Multifunction DAQ
Two 16-bit analog outputs (833 kS/s)
24 digital I/O; two 32-bit counters; digital triggering
Correlated DIO (8 clocked lines, 1 MHz)
Includes NI-DAQmx, VI Logger Lite data-logging software, and other measurement services  NIST-traceable calibration and more than 70 signal conditioning options
Select high-speed M Series for 5x faster sampling rates or high-accuracy M Series for 4x resolution
The National Instruments PCI-6225 is a low-cost multifunction M Series data acquisition (DAQ) board optimized for cost-sensitive applications. The board offers 80 analog inputs, two analog outputs,
24 digital I/O lines, and two counter/timers. The NI PCI-6225 is ideal
for applications including data logging, control, and sensor and high-voltage measurements when used in conjunction with NI signal conditioning.
Synchronize the operations of multiple boards using the RTSI bus.
Low-cost M Series devices incorporate advanced features such as the NI-STC 2 system controller, NI-PGIA 2 programmable amplifier, and NI-MCal calibration technology to increase performance and accuracy. Also
consider the high-speed M Series devices for 5X faster sampling rates or
the high-accuracy M Series devices for 4X resolution and superior
measurement accuracy.
Cables and Accessories
The PCI-6225 requires two cables and accessories to use all I/O. For optimal performance,
NI recommends using the SHC68-68-EPM extended performance, shielded cable for connector 0 and the SHC68-68 basic, shielded cable for connector 1. For ease-of-use and convenience, the PCI-6225 will ship with cable identification labels
to help with distinguishing the SHC68-68-EPM from the SHC68-68. Jump-start your application development by learning the seven steps to design, set up,
and test your data acquisition system with the “Data Acquisition: 7 Steps to
Success Tutorial Kit”.
Calibration and Warranty Services
All M Series devices have a 3-year manufacturing warranty. Additional warranty and calibration services may
be purchased at the same time as purchasing the device. Choose from extended
warranty, lifetime warranty, or lifetime warranty with one basic calibration service.
Refer to Hardware Services linked below for more information.
Driver Software
M Series devices work with multiple OSs, with three driver software options
including NI-DAQmx, NI-DAQmx Base, and the Measurement Hardware DDK. To learn more about driver
software or to download a driver, click on the “Download NI drivers” link below.
M Series devices are not compatible with the Traditional NI-DAQ (Legacy) driver.
Application Development Environments
M Series devices are compatible with the following versions (or later) of NI
application software LabVIEW 7.x, LabWindows/CVI 7.x, or Measurement Studio
7.x;SignalExpress 1.x; VI Logger 2.0; or LabVIEW with the LabVIEW Real-Time Module 7.1. M Series devices are also compatible with Visual Studio .NET,
Visual Basic 6, and C/C++/C#. For additional information on supported application
development environments, please refer to the Read Me documentation
associated with the driver software.
关 键 词:NI PCI 多功能 数据采集卡
公司名称: 美国国家仪器(NI)有限公司
联 系 人: 市场部
电  话: 021 50509800
传  真: 021-65556244
地  址: (上海市)上海浦东张江集电港二期张东路1387号第45幢
邮  编: 201203
主  页: http://www.ni.com/china
  • NI PCI-6521数字I/O卡
  • NI PCI6534高速32位并行数字I/O接口
  • PCI-6601多功能DAQ
  • NI PCI-6527数字I/O板卡
  • NI PCI6733 多功能DAQ
  • NI PCI-6013 低价位多功能DAQ
  • NI PCI6509数字I/O模块
  • NI PCI5122高分辨率数字化仪
  • NI PCI6722 多功能DAQ
  • NI PCI6624 数字I/O板卡
  • NI C系列USB单模块外盒(NI C系列USB)
  • NI PCI6514(32路输入,32路源极输出)
  • PCI6528 (60 V 通道间隔离)数字I/O
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
