1GHz 数字示波器
LeCroy LC574AL
厂家:美国力科 ( 26x40x45cm,20kg)
- 带宽 1 GHz 四通道
- 单通道最大采样率
双通道模式 2GSa/s 四通道模式 1GSa/s
- 存储深度最大 8 M
- 9" 彩色CRT显示
- 通信控制接口 GPIB 和 RS-232-C
- 外接显示接口 VGA
9"彩色显示
LeCroy provides a very large, sharp oscilloscope screen that is 50% larger in total viewing area than a 7" screen.
Its powerful features include Analog Persistence, Color-Graded Persistence, Full Screen mode, Opaque or Transparent display, color association, and personal color schemes. These provide the user with outstanding benefits that accelerate visual processing and effective communication of on-screen information.
高速采集
The design and debug of fast digital systems and the need to capture fast transient signals require high-speed signal capture. The LC574A four-channel, 1 GS/s, 1 GHz bandwidth DSO operates at a 4 GS/s sample rate for single-channel inputs. The high sample rate, bandwidth and the 1 GHz trigger bandwidth provide a flexible solution for capturing and viewing fast risetime signals.
二手数字示波器:010-62123258 / buy17@126.com
