产品介绍: |
产品简介: RA-734提供隔离数字量输入/输出通道,隔离保护电压可达到2500VDC。该卡是要求采取高电压隔离工业应用的理想选择。此外,所有输出通道都提供高电压保护。
Product Introduction:
The PRA-734 cards offer isolated digital input channels as well as isolated digital output channels with isolation protection up to 2,500 VDC, which makes it ideal for industrial applications where high-voltage isolation is required. In addition, all output channels are provide high-voltage protection.
| 性能特点: |
◆ 32路隔离数字量输出通道
◆ 高输出驱动能力
◆ 输出通道高电压隔离(1,000V DC)
◆ 用于隔离输出通道的D型接口
◆ 隔离输出通道上的高汇点电流(200mA/每通道) |
