产品介绍: |
产品简介: PRA-713B是一款12位32路A/D数据采集卡,它能够对每路模拟量输入提供电压保护,是工业测量和监控的理想解决方案。该卡良好的接地的四层PCB上提供了32路模拟输入量和2个DC/DC转换器。每路模拟量输入的增益都可以软件编程。光隔离在模拟量输入和PC之间提供了500VDC得支流隔离保护,能够防止PC机外设被输入线上的高电压损坏。对那些要求低价位,但对灵活性,稳定性和高隔离保护有要求的用户来说,PRA-713B是最理想的选择。PRA-713B带有PRAD-781接线端子板和1根DB-37电缆。
Product introduction:
The PRA-713B is a 12-bit 32-channel A/D card which offers high-voltage isolation on each analog input. The PCL-813B is an extremely cost effective solution for applications in industrial measurement and monitoring. The card offers 32 A/D channels with software programmable gain on each channel and two DC-to-DC converters on a 4-layer PCB with an integral ground plane. Optically-isolated inputs provide over 500 VDC of isolation between the analog inputs and the PC, protecting the PC and peripherals from damage due to high voltages on the input lines. The PCL-813B is ideal for situations where the bud get-conscious user requires flexibility, stability and a high level of isolation protection. The PCL-813B comes with the PRA-713B wiring terminal board and a DB- 37 cable assembly.
| 性能特点: |
◆ 32路单端模拟量输入
◆ 500 V DC 隔离保护
◆ 12位逐次比较式A/D转换器
◆ 程序控制A/D触发及数据传输
