IB820 产品规格 处理器架构 Socket 478 处理器 Intel® Pentium® 4 processor 1.30 GHz ~ 3.06GHz+ 处理器外频 533MHz / 400MHz 芯片组 Intel® 845G chipset L2 快取 128K/256K/512K, CPU integrated BIOS Award BIOS, ACPI supported 系统内存 Two DDR sockets support up to 2GB DDR SDRAM 视频 Intel® 845G/GL integrated VGA Supports CRT interface Optional VGA ATI Mobility M7 graphics controller 16MB/32MB embedded memory Frame buffer (DDR, AGP4) LVDS/TMDS/dual CRT interface Integrated MPEG-2 decode capability 网络 ICH4 integrated Ethernet controller 10Base-T / 100Base-TX Protocol Optional Intel® 82540 Gigabit Ethernet 音频 ICH4 integrated audio Optional AC97 codec and audio cable LPC I/O W83627HF chipset supports IrDA x 1, Parallel x 1, COM1 (RS232), COM2 (RS232/422/485), FDC up to 2.88MB (3 Mode support), Hardware Monitor (3 thermal inputs, 6 voltage monitor inputs, VID0-4, 3 fan headers) IDE 界面 Built in ICH4; Two enhanced IDE supports 4 IDE devices including UDMA33/66/100, PIO mode 4 and bus master FDD 界面 Supports up to two floppy disk drives: 3.5" and/or 5.25" drives; 3 Mode support 并口 One parallel port supports SPP/EPP/ECP 串口 One RS-232/422/485 and one RS-232 port 看门狗定时器 Generates system reset; 256 levels Solid State Disk 界面 Supports 2MB~144MB M-Systems DiskOnChip flash disk 硬件侦测 Built in W83627HF; monitors system/CPU temperature and voltage status USB Supports 6 USB ports, USB 2.0 compliant IrDA Pin header 键盘鼠标 PS/2 type 其他特点 ISA High Drive PCI to ISA Bridge (ITE 8888) One MicroPCI socket ATX 12V power connector 功耗需求 Intel® Pentium® 4 processor 1.8GHz with 512MB DDR SDRAM +5V: 5.7A +12V: 8.5A Intel® Pentium® 4 processor 2.2GHz with 512MB DDR SDRAM +5V: 6.4A +12V: 6.3A Form Factor Full Size CPU Card 产品尺寸 338mm x 122mm (13.3" x 4.8") 环境条件 工作温度 0C~60C (32F~140F) 储存温度 -20C~80C (-68F~176F) 相对湿度 10%~90% (non-condensing)
