特点 插座为 478 支持 HT Pentium4 最大 3.06GHz Intel® 845GE/GV 芯片组, 533MHz 和 400MHz FSB Micro ATX form factor 2个 DDR 插口 最大支持 2GB PC200/266/333 DDR SDRAM 1 AGP 4X 槽 (MB840F), 3 PCI 槽 看门狗定时器, 4个 USB 串口, 支持USB 2.0 MB840 产品规格 处理器架构 Socket 478 处理器 Intel® Pentium® 4 processor, 1.7GHz~3.06GHz+ Hyper-Threading supported 芯片组 Intel® 845GE/GV chipset Processor Side Bus Frequency 533MHz (133MHz x4)/400MHz (100MHz x4) L2 快取 128K/256K/512K, CPU integrated BIOS Award BIOS, ACPI supported 系统内存 Two DDR slots Support up to 2GB PC200/266/333 DDR SDRAM 视频 Intel® 845GE/GV chipset integrated, AGP 4X 网络 Realtek 8100BL LAN Controller (10/100Mb) Audio ICH4 integrated audio with AC97 Codec ALC650 LPC I/O Winbond 83627HF supports IrDA x 1, Parallel x 1, COM1, COM2 (RS232), FDC up to 2.88MB (3 Mode support), hardware monitoring IDE 界面 Built in ICH4; Two enhanced IDE supports 4 IDE devices including UDMA33/66/100, PIO mode 4 and bus master FDD 界面 Supports up to two floppy disk drives: 3.5" and/or 5.25" drives; 3 Mode support 并口 One parallel port supports SPP/EPP/ECP 串口 RS-232 x2 看门狗定时器 Generates system reset; 256 levels 硬件侦测 Built in Winbond W83627HF; monitors system/CPU temperature and voltage status USB USB 2.0 compliant Supports 4 USB ports IrDA Pin header 键盘/鼠标 PS/2 type keyboard and mouse connectors 扩充槽 1 AGP (MB840F only), 3 PCI 电源 ATX 12V power connector Form Factor Micro ATX motherboard 尺寸 244mm x 244mm (9.5" x 9.5") 功耗需求 Intel® Pentium® 4 processor 2.4GHz (512KB, 0.13u) w/ 256MB DDR Memory +5V: 0.69A; +12V: 4.95A 2.2 GHz Intel® Celeron® processor (128KB, 0.13u) w/ 256MB DDR Memory +5V: 0.61A; +12V: 5.15A 工作温度 0<C~60<C (32<F~140<F) 存储温度 -20<C~80<C (-68<F~176<F) 相对湿度 10%~90% (non-condensing)
