产品介绍: |
特点 断电时网络旁设 (LAN1-LAN2) 支持 300MHz~1GHz VIA Eden EBGA 电源 CPU 4 Realtek 8100C以太网控制器 128MB内存 集成VGA最大8MB 共享内存 Mini PCI 槽, 2 USB, 看门狗 Compact Flash 插座, 2 COM ports 支持Optional 2.5-inch Hard Disk FWA7204 产品规格 处理器 VIA Eden Low Power CPU, 300MHz / 1GHz L2 Cache: 64K 系统内存 128MB on board 网络 Four Realtek RTL8100C Ethernet controllers, 10/100 Base-T Storage Compact Flash via IDE ports LED Power LED, Status LED, ACT and Link LED indicators for network activity USB One USB port, version 1.1 I/O 界面 One RS232 DB-9 connector Mini PCI Mini PCI socket supports optional Mini PCI interface cards for development purposes 功耗需求 20 watt, 5V 4A 尺寸 22.5cm (L) x 15.6cm (W) x 3.5cm (H) Options HDD bracket for installing a 2.5-inch HDD, 20W power adapter.
