点击看-HDB-42732  刀片-大图
产品名称: HDB-42732 刀片
型  号: HDB-42732
品  牌: 集智达
产品介绍: SYSTEM
PROCESSOR
Dual Intel P4 Xeon with 512KB on-die L2 cache,Up to 3GHz+,512KB on-die L2 cache,FCBGA2/INT3 package,Support enhanced SIMD instruction
PROCESSOR SOCKET Two 604-pin Socket-F type sockets
MAIN MEMORY
Two 184pin DIMM right-angle type sockets
CORE LOGIC CHIPSET (NORTH BRIDGE)
Intel E7501,Support 400/533 MHz FSB,Support DDR200/266 SDRAM
CORE LOGIC CHIPSET (SOUTH BRIDGE)
Support two ATA/100 IDE channels (one for on-board storage, one for chassis CD-ROM drive access routed thru backplane),Intel ICH4,Support one front access USB 2.0 port
BIOS
Award System BIOS,Support MPS 1.4,Support serial console redirection
Host Bus to PCI-X
Bridge Intel P64H2,Dual 64bit/133MHz PCI-X bus (one for on-board 64-bit PCI devices, one for PCI-X add-on slot)
I/O EXPANSION
One on-board 64bit/133MHz PCI-X vertical type slot,Add-on card dimension 220mm(L)x110mm(W)x9mm(H)
Server Management Controller
Hardware monitor controller for voltage sensor, fan tachometer, temperature sensor,Microprocessor,IPMI V1.5,
RTC
Intel ICH4 built-in,256Bytes battery backup NVRAM,Re-chargeable type battery
DISAPLAY
CHIPSET
ATI RAGE XL Graphics controller with 8MB Video Memory,Hardware acceleration for 2D/3D
VGA
One VGA port for front access or rear access routed thru backplane
I/O
ON-BOARD I/O
One 8042 compatible Keyboard Controller, keyboard and mouse port routed thru backplane,One 16C550 UART for rear access routed thru backplane
NETWORKING
Two Gigabit Ethernet for rear access routed thru backplane,Broadcom 5704S Gigabit Ethernet Controller,Two full duplex 1000Mb Based T ports,Complied with PCI V2.1, IEEE802.3, 802.3u, 802.3ab,Support Wake on LAN,Support PXE boot,One Fast Ethernet for rear access routed thru backplane,Intel 82591NIC controller,One full duplex 10/100Mb Based TX port,Complied with PCI V2.1, IEEE802.3, IEEE 802.3u,Support Wake on LAN,Support PXE boot
STORAGE
Bracket to hold two of the following devices…,2.5"IDE HDD,Disk-On-Module (vertical or right angle type),CompactFlash Adapter
关 键 词:HDB-42732 集智达
公司名称: 北京集智达工业控制技术有限公司
联 系 人: 王爽
电  话: 010 58858530-8005
传  真: 010-58858535
地  址: (北京市)北京海淀区上地东路1号院盈创动力E座306室
邮  编: 100085
主  页: http://www.jizhida.com
  • 集智达 3.5寸单板电脑 SBC-3647(SBC-3647)
  • 集智达 SBC-3583 3.5″嵌入式单板电脑(SBC-3583)
  • 集智达 3.5寸单板电脑 SBC-3641(SBC-3641)
  • 集智达 3.5寸单板电脑 SBC-3701(SBC-3701)
  • 集智达 串口通讯服务器 JZD7082系列(JZD7082系列)
  • JZD-S768型指纹+摄像头考勤门禁机(JZD-S768型)
  • TITAN-N9工业加固便携机(TITAN-N9)
  • W-130 军用加固笔记本(W-130)
  • IPC-4000 工业机箱(IPC-4000)
  • PCM-5149 PC/104外围板(PCM-5149)
  • PCM-5120 PC/104外围板(PCM-5120)
  • PCM-5135 PC/104外围板(PCM-5135)
  • 集智达-Diamond-440A 工业机箱(Diamond-440A)
    立 即 发 送 询 问 信 息
    数据采集系统
    压力位移传感器
    SV系列迷你矢量型变频器
    LCD液晶显示模块
    液晶显示屏
    百兆、千兆工业以太网交换机
    研华工控机
    CPU主板
    工业级串口服务器
    工业级以太网交换机
    经营许可证编号:粤B2-20040325
    网安备案编号:4403303010105
