产品介绍: |
SYSTEM
PROCESSOR Dual AMD Opteron with 1MB on-die L2 cache,Up to 2.4GHz,1MB on-die L2 cache,Support 64-bit instruction
PROCESSOR SOCKET Two Opteron sockets
MAIN MEMORY Four 184pin DIMM verticle type sockets
CORE LOGIC CHIPSET (NORTH BRIDGE) Embedded in Opteron processor,Support DDR266/333/400 SDRAM
CORE LOGIC CHIPSET (SOUTH BRIDGE) AMD8111,Support two ATA/100 IDE channels (one for on-board storage, one for chassis CD-ROM drive access routed thru backplane),Support one front access USB port
BIOS AMI System BIOS,Support MPS 1.4,Support serial console redirection
Host Bus to PCI-X Bridge AMD 8131,Dual 64bit/133MHz PCI-X bus (one for on-board 64-bit PCI devices, one for PCI-X add-on slot)
I/O EXPANSION One on-board 64bit/133MHz PCI-X vertical type slot,Add-on card dimension 220mm(L)x110mm(W)x9mm(H)
Server Management Controller Hardware monitor controller for voltage sensor, fan tachometer, temperature sensor,Microprocessor,IPMI V1.5
RTC AMD 8111built-in,256Bytes battery backup NVRAM,Re-chargeable type battery
DISAPLAY
CHIPSET ATI RAGE XL Graphics controller with 8MB Video Memory ,Hardware acceleration for 2D/3D
VGA One VGA port for front access or rear access routed thru backplane
I/O
ON-BOARD I/O One 8042 compatible Keyboard Controller, keyboard and mouse port routed thru backplane,One 16C550 UART for rear access routed thru backplane
NETWORKING Two full duplex 1000Mb Based T ports,Complied with PCI V2.1, IEEE802.3, 802.3u, 802.3ab,Support Wake on LAN,Support PXE boot,One Fast Ethernet for rear access routed thru backplane,Intel 82591NIC controller,One full duplex 10/100Mb Based TX port,Complied with PCI V2.1, IEEE802.3, IEEE 802.3u,Support Wake on LAN,Support PXE boot,Two Gigabit Ethernet for rear access routed thru backplane,Broadcom 5704S Gigabit Ethernet Controller
STORAGE Bracket to hold two of the following devices…,2.5"IDE HDD,Disk-On-Module (vertical or right angle type),CompactFlash Adapter
