产品介绍: |
MOTEC精密行星减速机有APE,APX,APS,WAPS四个系列产品供您选择。APE是一种经济型圆法兰输出的行星减速机。APX减速机的输出方式为方法兰,通孔。且其较高的精度和很好的性价比一直为用户青睐。 MOTEC精密行星减速机 APS,WAPS系列减速机时高精密星减速机,齿系为三分,最高为一分。其中WAPS为直角输出型减速机,在高精度同时满足了空间要求。 MOTEC精密行星减速机广泛应用于航天,航空,数控设备,焊接,切割,包装,印刷等领域,相信这四大系列上百种减速机一定会有适合您的产品。
点击以下系列名称,查看详情:
APE系列 WAPE系列 APX系列 APS系列 WAPS系列 APH系列 WAPH系列
< language=JavaScript src="/cn/js/motec-dh.js">>
< language=JavaScript>
var mmenus = new Array();
var misShow = new Boolean();
misShow=false;
var misdown = new Boolean();
misdown=false;
var mnumberofsub=0;
var musestatus=false;
var mpopTimer = 0;
mmenucolor="#ffffff";mfontcolor="MenuText";mmenuoutcolor="#CCCCCC";mmenuincolor="#CCCCCC";mmenuoutbordercolor="#ffffff";mmenuinbordercolor="#ffffff";mmidoutcolor="#A9DA1D";mmidincolor="#799310";mmenuovercolor="#cc3399";mitemedge="0";msubedge="1";mmenuunitwidth=60;mmenuitemwidth=120;mmenuheight=25;mmenuwidth="100%";mmenuadjust=0;mmenuadjustV=0;mfonts="font-family: 宋体; font-size: 9pt; color: MenuText; ";mcursor="hand";
var swipeSteps = 4;
var swipemsec = 25;
var swipeArray = new Array();
function swipe(el, dir, steps, msec) {
if (steps == null) steps = swipeSteps;
if (msec == null) msec = swipemsec;
if (el.swipeIndex == null)
el.swipeIndex = swipeArray.length;
if (el.swipeTimer != null)
window.clearTimeout(el.swipeTimer);
swipeArray[el.swipeIndex] = el;
el.style.clip = "rect(-99999, 99999, 99999, -99999)";
if (el.swipeCounter == null || el.swipeCounter == 0) {
el.orgLeft = el.offsetLeft;
el.orgTop = el.offsetTop;
el.orgWidth = el.offsetWidth;
el.orgHeight = el.offsetHeight;
el.swipeCounter = steps;
el.style.clip = "rect(0,0,0,0)";
window.setTimeout("repeat(" + dir + "," + el.swipeIndex + "," + steps + "," + msec + ")", msec);
function repeat(dir, index, steps, msec) {
el = swipeArray[index];
var left = el.orgLeft;
var top = el.orgTop;
var width = el.orgWidth;
var height = el.orgHeight;
if (el.swipeCounter == 0) {
return;
else {
el.swipeCounter--;
el.style.visibility = "visible";
switch (dir) {
case 2:
el.style.clip = "rect(" + height*el.swipeCounter/steps + "," + width + "," + height + "," + 0 + ")";
el.style.top = top - height*el.swipeCounter/steps;
break;
case 8:
el.style.clip = "rect(" + 0 + "," + width + "," + height*(steps-el.swipeCounter)/steps + "," + 0 + ")";
el.style.top = top + height*el.swipeCounter/steps;
break;
case 6:
el.style.clip = "rect(" + 0 + "," + width + "," + height + "," + width*(el.swipeCounter)/steps + ")";
el.style.left = left - width*el.swipeCounter/steps;
break;
case 4:
el.style.clip = "rect(" + 0 + "," + width*(swipeSteps - el.swipeCounter)/steps + "," + height + "," + 0 + ")";
el.style.left = left + width*el.swipeCounter/steps;
break;
el.swipeTimer = window.setTimeout("repeat(" + dir + "," + index + "," + steps + "," + msec + ")", msec);
var mtmpleft="";
var mtmptop="";
function hideSwipe(el) {
el.style.visibility = "hidden";
el.swipeCounter = 0;
if(mtmpleft!="")el.style.left = mtmpleft;
if(mtmptop!="")el.style.top = mtmptop;
function stoperror(){
return true;
window.onerror=stoperror;
function mpopOut() {
mpopTimer = setTimeout(mallhide(), 500);
function getReal(el, type, value) {
temp = el;
while ((temp != null) && (temp.tagName != "BODY")) {
if (eval("temp." + type) == value) {
el = temp;
return el;
temp = temp.parentElement;
return el;
function mMenuRegister(menu)
mmenus[mmenus.length] = menu
return (mmenus.length - 1)
function mMenuItem(caption,command,target,isline,statustxt,level,img,sizex,sizey,pos){
this.items = new Array();
this.caption=caption;
this.command=command;
this.target=target;
this.isline=isline;
this.statustxt=statustxt;
if(level!=null){mnumberofsub++;
this.hasc=mnumberofsub;}
this.level=level;
this.img=img;
this.sizex=sizex;
this.sizey=sizey;
this.pos=pos;
function mMenu(caption,command,target,img,sizex,sizey,pos){
this.target=target;
this.img=img;
this.sizex=sizex;
this.sizey=sizey;
this.pos=pos;
this.id=mMenuRegister(this);
function mMenuAddItem(item)
this.items[this.items.length] = item
item.parent = this.id;
this.children=true;
mMenu.prototype.addItem = mMenuAddItem;
mMenuItem.prototype.addsubItem = mMenuAddItem;
function mtoout(src){
src.style.borderLeftColor=mmenuoutbordercolor;
src.style.borderRightColor=mmenuinbordercolor;
src.style.borderTopColor=mmenuoutbordercolor;
src.style.borderBottomColor=mmenuinbordercolor;
src.style.backgroundColor=mmenuoutcolor;
src.style.color=mmenuovercolor;
function mtoin(src){
src.style.borderLeftColor=mmenuinbordercolor;
src.style.borderRightColor=mmenuoutbordercolor;
src.style.borderTopColor=mmenuinbordercolor;
src.style.borderBottomColor=mmenuoutbordercolor;
src.style.backgroundColor=mmenuincolor;
function mnochange(src){
src.style.borderLeftColor=mmenucolor;
src.style.borderRightColor=mmenucolor;
src.style.borderTopColor=mmenucolor;
src.style.borderBottomColor=mmenucolor;
src.style.backgroundColor=;
src.style.color=mfontcolor;
function mallhide(){
for(var nummenu=0;nummenudocument.body.clientWidth+document.body.scrollLeft)
menuid.style.left=document.body.clientWidth+document.body.scrollLeft-mmenuitemwidth;
mtmpleft=menuid.style.left;mtmptop=menuid.style.top;swipe(menuid,2,4);
misShow=true;
function mshowsubmenu(menuid,pid,rid){
menuid.style.filter=Alpha(Opacity=80);
menuid.style.left=pid.offsetWidth+rid.offsetLeft;
menuid.style.top=pid.offsetTop+rid.offsetTop-3;
if(mmenuitemwidth+parseInt(menuid.style.left)>document.body.clientWidth+document.body.scrollLeft)
menuid.style.visibility=visible;
function mmenu_over(menuid,x){
toel = getReal(window.event.toElement, "className", "coolButton");
fromel = getReal(window.event.fromElement, "className", "coolButton");
if (toel == fromel) return;
if(x<0){
misShow = false;
mallhide();
mtoout(eval("mMenu"+x));
}else{
mallhide();
mtoin(eval("mMenu"+x));
mmenushow(menuid,eval("mMenu"+x));
clearTimeout(mpopTimer);
function mmenu_out(x){
if (misShow){
}else{
mnochange(eval("mMenu"+x));
mpopOut()
function mmenu_down(menuid,x){
if(misShow){
mmenuhide(menuid);
else{
misdown=true;
function mmenu_up(){
misdown=false;
function mmenuitem_over(menuid,item,x,j,i){
srcel = getReal(window.event.srcElement, "className", "coolButton");
for(nummenu=1;nummenu<=mnumberofsub;nummenu++){
var thesub=document.all[msubmenudiv+nummenu]
if(!(menuid==thesub||menuid.style.tag>=thesub.style.tag)){
msubmenuhide(thesub);
mnochange(document.all[mp+nummenu]);
document.all["mitem"+nummenu].style.color=mfontcolor;
if(item)document.all["mitem"+item].style.color=mmenuovercolor;
if(misdown||item){
mtoin(srcel);
else{
mtoout(srcel);
if(x==-1)mthestatus=eval("msub"+j).items[i].statustxt;
if(j==-1)mthestatus=mmenus[x].items[i].statustxt;
if(mthestatus!=""){
musestatus=true;
window.status=mthestatus;
function mmenuitem_out(hassub){
if(!hassub)mnochange(srcel);
if(musestatus)window.status="";
mpopOut()
function mmenuitem_down(){
mtoin(srcel)
misdown=true;
function mmenuitem_up(){
mtoout(srcel)
misdown=false;
function mexec3(j,i){
var cmd;
if(eval("msub"+j).items[i].target=="blank"){
cmd = "window.open("+eval("msub"+j).items[i].command+")";
}else{
cmd = eval("msub"+j).items[i].target+".location=\""+eval("msub"+j).items[i].command+"\"";
eval(cmd);
function mexec2(x){
var cmd;
if(mmenus[x].target=="blank"){
cmd = "window.open("+mmenus[x].command+")";
}else{
cmd = mmenus[x].target+".location=\""+mmenus[x].command+"\"";
eval(cmd);
function mexec(x,i){
var cmd;
if(mmenus[x].items[i].target=="blank"){
cmd = "window.open("+mmenus[x].items[i].command+")";
}else{
cmd = mmenus[x].items[i].target+".location=\""+mmenus[x].items[i].command+"\"";
eval(cmd);
function mbody_click(){
if (misShow){
for(var x=0;x<=mmenus.length;x++){
if(srcel.id=="mMenu"+x)
return;
for(x=1;x<=mnumberofsub;x++){
if(srcel.id=="mp"+x)
return;
mallhide();
document.onclick=mbody_click;
function mwritetodocument(){
var mwb=1;
var stringx=";
for(var x=0;x |
