产品说明: Product description
* 5个ISA槽,一面3ISA槽,另一面2ISA槽 5 slots , one side 3× PCI slot , the other side 2×ISA slot
* 4层PCB板,抗干扰设计 Four layers of PCB ,anti-interference designed
* AT电源 AT power supply
* ±5V,±12V电源LED指示灯 ±5V,±12Vpower supply LED light indicator
* 尺寸:175 mm (L)×80 mm(W)
Dimension:175 mm (L)×80 mm(W)
