性能参数:Functional parameters
产品简介: product introduction
祈飞网络安全平台具有稳定的性能和人性化设计,专为应用开发商、系统集成商和服务提供商设计,以提供网络连接的安全性,是最为经济实用的优质产品。
Pray fly’s Network Security Platform with suitable performance and humanity design, specialized for application developers, system integrators and service providers, designed to provide the security of network connections. It is the most economical and practical quality products.
产品规格: Product specifications:
◆ 结构:优质重型钢箱体,1U标准19″机架式机箱
Structure: high grade high-duty steel chassis,1U 19″standard rack mounted chassis
◆ 前面板:(可选) 优质电解板重型钢材料面板, OEM贴膜或丝印 (可选) OEM定制豪华铝面板
Front panel: (optional) electrolysis high grade high-duty steel panel,OEM film-pasting and printing
(optional) OEM ordering luxury aluminum panel
◆ 电源:350W工业电源
Power supply: 350W industrial power supply
◆ 驱动器空间:2个3.5〞空间
Disk drive housing: support two 3.5〞HDD
通风系统:Ventilation system:
◆ 2个620mm风扇和2个420mm风扇
2 x 620mm fans & 2 x 420mm fans
◆ 网口位置:后置网络接口
LAN location: rear network interface
◆ 主板说明:2个PRA-NB-8368VE4主板 Mother board introduction: two PRA-NB-8368VE4 mother boards
物理参数 Physics parameters:
◆ 外形尺寸: 436mm(L)×89mm(W)×410mm(H) Dimensions: 436mm(L)×89mm(W)×410mm(H)
工作温度:0℃~50℃ Operation temperature: 0℃~55℃
储存温度:-20℃~70℃ Storage temperature: -20℃~70℃
◆ 相对湿度:0~90%, 无冷凝
Relative humidity: 0~90%,non-condensing
◆ 抗冲击:10G峰-峰加速度(11ms)
Shock: 10G peak-to-peak acceleration (11ms duration)
◆ 抗震动:5-17Hz,0.1〞双峰位移;17-640Hz,1.5G峰-峰加速度
Vibration: 5-17Hz,0.1″double-amplitude displacement, 17-640Hz,1.5G peak to peak
◆ 电磁干扰:符合FCC/VDE A级标准
EMI: comply with FCC/VDE A standard
应用行业: 网络安全,视频会议,语音通讯等
Application: Network security, video conferencing, audio communications, etc.
参考选型: Selection guide
